process hung problem + self reset
Results 1 to 27 of 27
    Step1.Fix the problems you know about first then hunt for more.
    So how about disabling the analog stuff, ADCON, CCP . . . since you are using PortA.3
    Aug 2008
    I am wondering if it is not a power supply problem. After a few minutes the the PS starts to fail/drop voltage.
    Is the speaker direct connect to the PIC?
    no idon't think it's PS failing problem
    speaker connected though CAP
    Aug 2008
    well idon't know what is ( definitive ) the problem he umbrella the all issue in weird way ( chick datasheet and chick manual and all this stuff )
    if you see any error need to fix . please give me some guidance with few code lines
    also show me haw END program as you mention
    How about the PORTA.3 problem Joe mentioned?
    This will help
    Aug 2008
    This will help
    thanks dave i'll work on that and tell you what is outcome
    regards
    This will help
    Go into the data sheet, I know it's painful, but go in there anyway . . . Look to see what state port A initializes in when it is reset, you will probably discover it defaults to <b>Analog</b> operation, since you want Digital, <b> YOU </b> need to tell it<b><font color=red> how to be digital.</font color></b> Lots of registers to set, If you want simple then use old grandpaw chip like 16F84, or 16F628A, only CMCON to worry about. If you want lots of bells and whistles then you have to learn how to play them.
    Aug 2008
    well i have all those pic's you wrote
    but i don't want this circuit to work in my lab only
    it will work in rough and dirty environment so there is other things must be worried about so the design have more dimension than you imagine
    although am not from there but i bet you i worte more code lines than you
    wither on asm , C18 , C32 , css , pic basic pro
    take this advice
    work more ....
    and stop been futile person
    Quote Originally Posted by eng.alamin View Post
    take this advice
    work more ....
    Yep, I will bet you have too, I didn't know this was a competition, I thought I was trying to help you. My apologies, it won't happen again.
    Aug 2008
    This will help
    dear dave my circuit works good and the problem was in bi-pass capacitors
    these are some pictures of working
    regards
    last word in your program on the last line should be . . .
    <b><h2>END</h2></b>
    this I believe is a compiler directive, tells the compiler to end your code there. There is at least one exception to this rule, but not here and not now.
    Sorry about my English, I am American you know.
    Aug 2008
    i didn't said any thing about your English or about you generally
    but ...anyway that is advantage you must take it in good way to be usefull
    for ppl like me
    <b><h2>END</h2></b>
    well i may a dumb person but i wrote my code to be End less
    therefor my last line is
    <b><h2>GOTO main</h2></b>
    did you notice that or.. or... you never saw the code in my first post
  1. Pic reset and following lock up problem
    By zerosvarka in forum General
    Last Post: - 17th June 2009, 20:03
  2. LCD Reset Problem
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 08:55
  3. USART Problem , but don't know where, in pc? or in PIC?
    Last Post: - 15th July 2007, 08:12
  4. Reset problem
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2006, 06:46
  5. PIC problem, ways to do reset
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 26th May 2005, 14:31
