dummies guide to serin/serout by a dummie
Results 1 to 12 of 12
    May 2008
    Italy
    You cannot connect pic directly to the PC Rs232 port! You will need a maxim 232 as an interface.
    Read the manual where you will find some example of Tx and Rx.
    When You have setup your hardware, than remember you will send bytes via RS232 so your pic will need to decode the bytes sent via hyperterminal and act upon it. For instance I can set all 8 ports B to ON sending via RS232 "255" or set them all to OFF sending a "0".
    Hope it will help you
    Quote Originally Posted by aratti View Post
    Correct only if you are using the hardware serial from the PIC.
    If you plan to use SERIN or SERIN2 then all you have to do is use inverted mode.
    It is all in the manual
    That's a start . . . .
    now add a byte variable and a word variable, give them names meaningful to you, like LED1 or OUTPUTLED1 or MBOXVAR1, right now they will just be there, not doing anything, and compile to check for errors.
    edit: Set your port latch before the Tris register, that way when the tris turns the port to outputs, they will be set at the desired state, next we will work on config statements.
    Oct 2008
    Smile
    Good morning!!!
    This is my update code, adding 2 variables, when complied it says 85 words used.
    [codes]
    CMCON = 7 ' PortA = digital I/O
    VRCON = 0 ' A/D Voltage reference disabled
    TRISB = %11110000
    PortB = %00000000 ' Turn pins to low state
    Led1 var byte ' Led1 as a byte(8 bits) variable
    myvar var word ' myvar as a word(16 bits) variable
    begin:
    high PortB.0
    low PortB.0
    high PortB.1
    low PortB.1
    high PortB.2
    low PortB.2
    goto begin
    [\codes]
    thanks for the guidance,
    OK, let's not hijack Earl's thread any farther Please start a new thread in mel PbasicPro , and study this thread:http://www.picbasic.co.uk/forum/showthread.php?t=543
    To gain some insight on the next thing we are going to do, after which you will compile a working program into your PIC, which you wrote.
  1. USB HID Joystick for Dummies
    By Squibcakes in forum USB
    Last Post: - 2nd May 2014, 08:52
