1307 RTC accuracy?
Results 1 to 17 of 17
    May 2008
    Italy
    What Luciano meant is that body temperature variations will never be as great as ambient.
    Jan 2006
    Istanbul
    Quote Originally Posted by aratti View Post
    Comeon aratti!
    Get the point there!
    I dunno. I've left my watch in my truck for several days during winter, and it still kept perfect time. And it gets really cold here in winter...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Istanbul
    The watch must be more expensive then the truck then.
    ____________
    Same thing here... I've got a cheap watch that's wrapped around my rear view mirror year-round. Except for resetting it twice a year for daylight savings time, it holds time well, and we get wild temp variations up here. (and yes, the watch probably costs more than the car, at least you'd think so if you saw the car )
    Apr 2006
    New Hampshire USA
    Smile ppm
    Thanks for the interesting discussion.
    This is a handy online ppm calculator:
    http://www.maxim-ic.com/tools/calcul...fm/calc_id/rtc
    Quote Originally Posted by Maxim site
    This calculator converts timekeeping accuracy measurements from parts per million (PPM) to real-time accuracy described in seconds per day and minutes per year.
    The clock radio in my truck keeps good time also. Temperatures a little on the high side in SW Arizona.
    I have noticed it will loose a bit of time on long trips. Normal short trips and it is fine.
    Maybe it has something to do with speed and how long the speed is maintained changing time.
  1. Easy and Accurate Clocks without RTC IC
    By paul borgmeier in forum Code Examples
    Last Post: - 28th October 2013, 22:28
  2. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 11:28
  3. Using RTC to generate long time delays
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2007, 01:31
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 18:54
