1307 RTC accuracy?
Results 1 to 17 of 17
    Apr 2006
    New Hampshire USA
    Smile ppm
    Thanks for the interesting discussion.
    This is a handy online ppm calculator:
    http://www.maxim-ic.com/tools/calcul...fm/calc_id/rtc
    Quote Originally Posted by Maxim site
    This calculator converts timekeeping accuracy measurements from parts per million (PPM) to real-time accuracy described in seconds per day and minutes per year.
    The clock radio in my truck keeps good time also. Temperatures a little on the high side in SW Arizona.
    I have noticed it will loose a bit of time on long trips. Normal short trips and it is fine.
    Maybe it has something to do with speed and how long the speed is maintained changing time.
    Italy
    Einstein's Theory of Relativity?
    Crystal Considerations with Dallas Real-Time Clocks (RTCs)
    http://pdfserv.maxim-ic.com/en/an/AN58.pdf
    Considerations for Maxim Real-Time Clock Crystal Selection:
    http://pdfserv.maxim-ic.com/en/an/AN616.pdf
    Best regards,
    Luciano
    Quote Originally Posted by Luciano View Post
    That's the answer! MAXIM makes their chips around 40 degrees north, the original post'er lives on the equator. The earth rotates faster at the equator... Makes perfect sense!
  1. Easy and Accurate Clocks without RTC IC
    By paul borgmeier in forum Code Examples
    Last Post: - 28th October 2013, 22:28
  2. PIC 16F877 I2C communications
    By sigmoideng in forum General
    Last Post: - 13th July 2007, 11:28
  3. Using RTC to generate long time delays
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2007, 01:31
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. X1226 RTC - Help
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 14th August 2006, 18:54
