TCN75 Temp Sensor
Results 1 to 12 of 12
    Quote Originally Posted by Frozen001 View Post
    I2CREAD PORTC.4, PORTC.3,%10010001 ,$0, [temph,templ]
    temph is the first 8 bits, and templ is the next 8 bits.
    temph is difined earlier as the first byte in the word temp, while templ is defined at the second byte in the word temp.
    Now that I have the temperature reading, is thre a way to convert it to ascii characters so I can send them to my display?
    tempw var word
    tempw.highbyte = temph
    templw.lowbyte = templ
    lcdout $fe,1,DEC5 tempw
    Just like it shows in the LCDOUT section of the PBP manual.
    Aug 2008
    tempw var word
    Thanks for the information, but the display is not compatible with the LCDOUT routine. I got it working though, had to do some math. Working great so far.
    Thanks again...
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  3. Using WDT as a Temp Sensor?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 20th June 2006, 18:55
  4. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 16:55
  5. Temp sensor problem
    Last Post: - 14th June 2006, 15:49
