TCN75 Temp Sensor
Results 1 to 12 of 12
    Quote Originally Posted by Frozen001 View Post
    but I think I am more confued with the commands I2CREAD and I2CWRITE.
    After Startup, I have to send 10010001 to go into read mode. The sensor will acknowledge receipt (SDA low). After ACK, the sensor will clock out the data which I have to read.
    Ok, that sounds reasonable...
    YOU don't have to worry about SCL, SDA, ACK, NACK, this, that, the other thing, whatever...
    PBP and I2CREAD/I2CWRITE take care of that for you.
    All you have to do is provide the right parameters for said commands (i.e. addresses, data, etc).
    Aug 2008
    OK SO I tried the following:
    I2CWRITE PORTC.4, PORTC.3, $91, $00
    I2CREAD PORTC.4, PORTC.3,$90, [STR Temperature\16]
    And got nothing back...
    Aug 2008
    I connected the I2C port up to a scope, and I am getting pulses on the clock and SCL and the SDA pins, so I must be doing something correct... I think my problem is I am just not reading the data.
    May 2008
    Italy
    Verify that you have 5k resistor as pullup on I2C line. Also verify the address you have set (did you connect a0;a1;a2 to ground). Use write only to configure the chip or to set the setpoints.
    Use Read all the time you want to read out data from your chip. A 10- 15 millisecs delay between reading is recommended.
    good luck
    Aug 2008
    OK I have it reading the data correctly, it think:
    I2CREAD PORTC.4, PORTC.3,%10010001 ,$0, [temph,templ]
    temph is the first 8 bits, and templ is the next 8 bits.
    temph is difined earlier as the first byte in the word temp, while templ is defined at the second byte in the word temp.
    Now that I have the temperature reading, is thre a way to convert it to ascii characters so I can send them to my display?
    Look at the modifiers listed in the Serial out routines, HEX, BIN, STR Etc. . . usually, if my poor memory serves me, data goes ascii without the modifiers, but go look at them anyway, also while you are checking those out look also at the DIG and DEC modifiers, they do good things too.
    http://www.melabs.com/resources/pbpmanual/
    Aug 2008
    The modifier would be OK , but my display does not used a serial interface, rather I have to access address for each character to display (HDSP-2112).
    tempw var word
    tempw.highbyte = temph
    templw.lowbyte = templ
    lcdout $fe,1,DEC5 tempw
    Just like it shows in the LCDOUT section of the PBP manual.
    Aug 2008
    tempw var word
    Thanks for the information, but the display is not compatible with the LCDOUT routine. I got it working though, had to do some math. Working great so far.
    Thanks again...
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 11:45
  3. Using WDT as a Temp Sensor?
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 20th June 2006, 17:55
  4. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 15:55
  5. Temp sensor problem
    Last Post: - 14th June 2006, 14:49
