existing code for a data loggger
Results 1 to 11 of 11
    Sep 2008
    And how will you physically plug in to that pins that connect the SIM card to the phone to intercept said data?
    your making this out to sound like some underhanded fraudulent exercise when its blatently not...anyhow it will be soldered to the phones sim card socket
    Quote Originally Posted by sparkyadam View Post
    Well, it blatently could be, or it blatently might not be. Still sounds a bit fishy to me.
    As far as I know, you don't have to tap into the sim socket to pull SMS data or anything else stored on the card (except the actual identification information, PINS, etc).
    Hook up to the phone thru the appropriate connector and pull the data with a PC.
    Doesn't sound like a good idea either. At the speeds these cards run at these days, they're made to go on a socket for a reason. Go adding in extra wiring, solder, and so on, and you might ruin the electrical characteristics of the connection itself, thereby rendering the whole thing useless because of those disturbances. Probably didn't matter much 'back in the day' when things didn't run so fast...matters a lot more nowadays.
    Sep 2008
    ok thanks for your input, but this is to capture data whilst roaming but i will try a different less hostile site or just continue with the endless reading of texts
    Jeeze...go that way then...
    Jist of the story, I wouldn't doubt if you'll get the same answers on those other sites.
    (must not have liked the statement about getting the PINS and other encrypted info from the card...)
    Quacks like a duck and flies off like a duck.
    Sep 2008
    lol i understand what your saying but if that where the case i could just use my laptop with already designed hardware and software. it is the fact im trying to do it using a pic and an sd card from what i understand it is not very hard at all to capture an async data transmission the problem would be storing it on a card using a fat file format so what i am actually after is a suitable pic and code to receive the data stream and then transfer it to the card then i will transfer it to my pc using a async where the binary could be converted to txt
    Here is what the forum has to offer about SD cards.
    http://www.google.com/custom?q=sd+ca...picbasic.co.uk
    That is as far as I go with this.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. Making Program Code Space your playground...
  3. Data --> Modulated squre wave ???
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 27th August 2007, 03:18
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
