How to Reset Osccal Value
Results 1 to 9 of 9
Threaded View
  1. #3
    Quote Originally Posted by Pic2008 View Post
    Your syntax is wrong. Type the following in the code:
    OSCCAL = $30
    You sure ???
    From a µChip Datasheet ...
    2.2.2.7 OSCCAL Register
    The Oscillator Calibration register (OSCCAL) is used to
    calibrate the internal 4 MHz oscillator. It contains 6 bits
    to adjust the frequency up or down to achieve 4 MHz.
    The OSCCAL register bits are shown in Register 2-7.
    REGISTER 2-7: OSCCAL — OSCILLATOR CALIBRATION REGISTER (ADDRESS: 90h)
    Legend:
    R = Readable bit W = Writable bit U = Unimplemented bit, read as ‘0’
    - n = Value at POR ’1’ = Bit is set ’0’ = Bit is cleared x = Bit is unknown
    R/W-1 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 U-0 U-0
    CAL5 CAL4 CAL3 CAL2 CAL1 CAL0 — —
    bit 7 bit 0
    bit 7-2 CAL5:CAL0: 6-bit Signed Oscillator Calibration bits
    111111 = Maximum frequency
    100000 = Center frequency
    000000 = Minimum frequency
    bit 1-0 Unimplemented: Read as '0'
    Legend:
  1. IC12F508 with Internal Oscillator and Software Reset
    By karan123 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2009, 16:13
  2. pic reset sometimes
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 17:27
  3. Software Driven Reset Routine
    Last Post: - 11th April 2005, 00:53
  4. reset and interrupt vectors
    By dtoohey in forum mel PIC BASIC Pro
    Last Post: - 28th February 2005, 22:02
  5. Replies: 5
    Last Post: - 1st December 2004, 12:49
