How to Reset Osccal Value
Results 1 to 9 of 9
    Aug 2008
    Post
    Your syntax is wrong. Type the following in the code:
    OSCCAL = $30
    Quote Originally Posted by Pic2008 View Post
    OSCCAL = $30
    You sure ???
    From a µChip Datasheet ...
    2.2.2.7 OSCCAL Register
    The Oscillator Calibration register (OSCCAL) is used to
    calibrate the internal 4 MHz oscillator. It contains 6 bits
    to adjust the frequency up or down to achieve 4 MHz.
    The OSCCAL register bits are shown in Register 2-7.
    REGISTER 2-7: OSCCAL — OSCILLATOR CALIBRATION REGISTER (ADDRESS: 90h)
    Legend:
    R = Readable bit W = Writable bit U = Unimplemented bit, read as ‘0’
    - n = Value at POR ’1’ = Bit is set ’0’ = Bit is cleared x = Bit is unknown
    R/W-1 R/W-0 R/W-0 R/W-0 R/W-0 R/W-0 U-0 U-0
    CAL5 CAL4 CAL3 CAL2 CAL1 CAL0 — —
    bit 7 bit 0
    bit 7-2 CAL5:CAL0: 6-bit Signed Oscillator Calibration bits
    111111 = Maximum frequency
    100000 = Center frequency
    000000 = Minimum frequency
    bit 1-0 Unimplemented: Read as '0'
    Legend:
    Aug 2008
    You sure ???
    Yes, I'm sure. greensasquatch pointed that the original value from the chip is 30H.
    greensasquatch, without writing @ ORG 3FFh and @ RETLW 30h, have you tried the method I have written here?
    Wink
    Not so sure ...
    as you write the cal value in a "non protected" memory location and not at the end of the program memory ...
    you'll lose the cal value if you use the '675 for another program.
    so it's much better to write it at the end of the program memory, as programmers will read it ( and preserve it ) if you do not remember what you had done ... some weeks later.
    Here is a copy / paste from one of my programs 12F675:
    POKECODE @$3FF, $50  ' reintroduces osscal correction data
                             ' $3FF tells it where to code, $50 is the
                             ' Cal value unique to each individual chip.
    Aug 2008
    Thumbs up
    Not so sure ...
    There are two ways of doing it, either write to the OSCCAL directly or like you said, write at the end of program memory at 0x3FF.
    Good point.
  1. IC12F508 with Internal Oscillator and Software Reset
    By karan123 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2009, 16:13
  2. pic reset sometimes
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 17:27
  3. Software Driven Reset Routine
    Last Post: - 11th April 2005, 00:53
  4. reset and interrupt vectors
    By dtoohey in forum mel PIC BASIC Pro
    Last Post: - 28th February 2005, 22:02
  5. Replies: 5
    Last Post: - 1st December 2004, 12:49
