Total Newbie...
Results 1 to 18 of 18
Thread: Total Newbie...
    Well, hate to give you a bit of bad news, but you can't drive that LCD directly using PicBasicPro (maybe you already knew that, maybe not...)
    It's set up such that the I/O from the expander drive the LCD pins. The LCD is a standard parallel, Hitachi 44780 compatible type from the looks of it.
    If you do a Google search on that term, you should be able to find some documentation on how to drive it. I don't have anything with me at the moment or I'd attach it here.
    Once you get your head wrapped around driving that LCD thru the I/O expander, it should be a piece of cake.
    Since the board is from Microchip, I can't imagine somebody NOT having already written some 'libraries' to handle that.
    Aug 2008
    SO I guess that mean I must send the data out serially?? Like I said I hvae no programming experience, so everythign is new...
    Quote Originally Posted by Frozen001 View Post
    Not so much serially, but yes, serially.
    You'll have to set each pin individually, for each operation, every time, because you are accessing each pin, one at a time, thru the I/O expander.
    For instance, to send any character (assuming the LCD is initialized), you'll have to set each data bit, one at a time, set the R/W line (which can most likely be set once to WRITE when the prorgam starts, then leave it alone), then strobe the E line high then back low.
    Initialization is another thing... It's a long-ish sequence of setting various bits and/or bytes in the LCD itself, specifying modes, cursors, and so on. Nice thing is, once it's done, you don't have to do it again.
    Call me crazy, but it's not really that hard once you get a set of 'core' subroutines built-up. Not to mention, you'll really get a feel for how PBP works once you're done writing the mess...
    I suppose the other option is to disconnect that LCD and wire it up as shown in the PBP manual or something close to it...which isn't an unreasonable option. Might require a bit of trace cutting and/or rewiring. Not sure, haven't look at the datasheet for that board too closely.
    (just looked at the datasheet for the board)
    For that matter, you could probably disconnect the LCD from the mount it sits in right now, plug it into that expansion slot off to the side and set up each pin to do what you need.
    If you can blink an LED, you can build up to running an LCD.
    Maybe, but I doubt it. Like skimask said. Can not use it with standard PBP commands.
    Get a cheap LCD and hook it up like the example in the manual if you need to play with an LCD now.
    Or wait and do some research like skimask said. Or maybe Darrel will have a trick up his sleeve.
    Probably a bit over his head at the moment, but....
    http://www.picbasic.co.uk/forum/showthread.php?t=7038
    I thought about that, but after looking at the data sheet for the MCP23S17 I am not so sure he wants to go there yet either. The MCP23S17 appears to be programmable or at least configurable. Looks like a fun chip.
    From the data sheet:
    The MCP23017/MCP23S17 (MCP23X17) device
    family provides 16-bit, general purpose parallel I/O
    expansion for I2C bus or SPI applications. The two
    devices differ only in the serial interface.
    • MCP23017 – I2C interface
    • MCP23S17 – SPI interface
    The MCP23X17 consists of multiple 8-bit configuration
    registers for input, output and polarity selection. The
    system master can enable the I/Os as either inputs or
    outputs by writing the I/O configuration bits (IODIRA/B).
    The data for each input or output is kept in the corre-
    sponding input or output register. The polarity of the
    Input Port register can be inverted with the Polarity
    Inversion register. All registers can be read by the
    system master.
    The 16-bit I/O port functionally consists of two 8-bit
    ports (PORTA and PORTB). The MCP23X17 can be
    configured to operate in the 8-bit or 16-bit modes via
    IOCON.BANK.
    There are two interrupt pins, INTA and INTB, that can
    be associated with their respective ports, or can be
    logically OR’ed together so that both pins will activate if
    either port causes an interrupt.
    It is a handy chip to have around, especially (in my case) just to use to trip MOSFETs around. Keeps anything crazy away from my PICs. A bit spendy compared to buying a large-ish I/O count PIC around, but so EEAASSYY to hook up...
    Aug 2008
    I would rather not hack the board up at this point....
    If I could get this all striaght in my haed I know I can get the LDC display working...
    Lookint at the expander datasheet and the demo board schematic it looks like LCD Data Lines (DB0B7) are connected to the GPIO lines (GPB0:GPB7). LCD RD is on GPA7 and LCD E is on GPA6.
    The Pic is connected to the expander like this:
    PIC Expander
    RC3 --> SCK
    RC5 --> SI
    RF6 --> Reset
    Knowing that How do I cammand the expander to do what I want it to do?
    Thanks for all you help so far... it has been GREAT!!
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 18:45
  2. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 17:48
  3. Total Motor Currents
    By Darrel Taylor in forum Off Topic
    Last Post: - 13th October 2008, 01:50
  4. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 10:56
  5. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 10:01
