Total Newbie...
Results 1 to 18 of 18
Thread: Total Newbie...
    Aug 2008
    Default Total Newbie...
    Hi all I am totally new to programing Pics, and I am looking for some good tutorials.
    I currently am using Microchips PIC18 explored board, along with PICBasic Pro. The Pic is an 18F8722.
    Right now I have gott two pieces of code to work, I can blink an LED, and I can turn an LED on and off when I press a button... sounds simple, but like I said I am totally new.
    What I want to do next is to have the 8 on board leds display the status of 8 bits, but I am totally lost on how to do this...
    Any help would be great!
    Lou
    Welcome to the forum.
    This example might do the trick
    http://www.microengineeringlabs.com/...pbc/countx.bas
    Aug 2008
    Thanks...
    I actually got it working before I read this... Had to set the Port as Outputs...
    Now my next question:
    The PIC18 explored poard has an LCD display on it. It is connected through an SPI I/O expander, MCP23S17. How do in therface it??? Microchips Manual is totally useless for me since I have no programming background...
    The user guide states this:
    An LCD display with two lines, 16 characters each, is connected to the SPI I/O
    expander, MCP23S17. The two control lines and eight data lines are connected to the
    I/O expander.
    The I/O expander has an SPI interface that connects it to the microcontroller.The I/O
    expander is disabled or enabled from the SPI by jumper JP3.
    Not familiar with that board. Do you have a link to the docs?
    Aug 2008
    http://www.microchip.com/stellent/id...cName=en535770
    Well, hate to give you a bit of bad news, but you can't drive that LCD directly using PicBasicPro (maybe you already knew that, maybe not...)
    It's set up such that the I/O from the expander drive the LCD pins. The LCD is a standard parallel, Hitachi 44780 compatible type from the looks of it.
    If you do a Google search on that term, you should be able to find some documentation on how to drive it. I don't have anything with me at the moment or I'd attach it here.
    Once you get your head wrapped around driving that LCD thru the I/O expander, it should be a piece of cake.
    Since the board is from Microchip, I can't imagine somebody NOT having already written some 'libraries' to handle that.
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 17:45
  2. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 16:48
  3. Total Motor Currents
    By Darrel Taylor in forum Off Topic
    Last Post: - 13th October 2008, 00:50
  4. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 09:56
  5. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 09:01
