Measuring Volts and Amps digitally
Results 1 to 26 of 26
    Jun 2007
    Mansfield, UK
    I think i understand it now. If 5A is the maximum and the output increases by 185mV for each amp then the output range should be 0-925mV. If vcc is 5 then you add 2.5 giving 2.5-3.425V for positive so the entire range must be 1.575-3.425V.
    Ive read a datasheet for a PIC that has ADC but i didnt see anything about the lowest input voltage (unless i missed it or didnt understand it). Would i be right in saying that you take the output from the other chip and lower it so the range becomes 0-1.85V and set the PICs Vref to 1.85V? I think this is what the amplifier thing was about that i read somewhere. I think the idea is to stretch the 1.85V so the range goes from 0V all the way up to 5V so the PIC can read it easier
    I dont think i should have this problem using the resistor method because i can set the PICs Vref to the vdd pin (5V) then use the potential divider circuit to make sure its output is 5V when a little over the maximum amount of amps are being drawn (im making it a little over so i can add overload warning and safety cutoff)
    Where does 30 come into it? On the main page it said +/- 5A to 30A
    Quote Originally Posted by The Master View Post
    Different chip versions....
    Jun 2007
    Mansfield, UK
    Ahh, I see. I was getting confused before because it looked like the range of the chip was 5-30. I see now at the bottom of the other page there are 3 versions of that chip with different ratings
    Dec 2005
    You have some options:
    1. Use +5V Vdd as Vref and use it as is with reduced sensitivity
    2. Use a lower external VRef (which could be as simple as a voltage divider from Vdd)
    3. Use Vdd as Vref and an opamp setup for DC gain to amplify the signal
    However, all this is the easy part. When measuring AC voltage/current you will need to sample both many times per half-cycle (what frequencies are you dealing with?) and average the readings over each half-cycle. This also means you'll need to detect zero crossing.
    Jun 2007
    Mansfield, UK
    I think for the actual project im going to use vdd because the potential divide part can change its value to make use of the full 5V (i dont have any outputs 5V or less).
    The frequency is 50Hz (UK AC) but because its DC ripple i guess that makes it 100Hz. As i said before im going to only take the highest value. If i sample it at about 400 times a second then at least one sample will be extremely close to the absolute max. Because of DC ripple it also has 2 chances per second to get as close as possible. I can then discard all the lower readings. The highest value will be reset after each 400 samples so it can detect a drop in current.
    Im not sure if a PIC chip can check the ADC chanels that fast though. I might need a higher resonator. If using 10-bit then the chip can detect 1024 different voltage levels. At 5V max each level is 4.8828125mV. As long as the input value is within 4.8828125mV of the highest point in the DC ripple i should get an accurate reading. The good thing about DC ripple (or any kind of sinewave based line) is that it stays near the top for a longer period of time than any other point in the wave but still i might need more than 4 sample points on each bump. To make it even worse the pic chip will have to deal with 8 ADC pins. It might be an idea to split the work between multiple PICs
    The frequency is 50Hz (UK AC) but because its DC ripple i guess that makes it 100Hz......................
    If you run that 100hz DC ripple across a capacitor with a very small value bleed resistor, said capacitor will quickly charge up to the peak value of that ripple, thereby negating your need to quickly sample the output, maybe even isolate it with a diode so it (the cap) can't bleed back into your supply. Basically, you end up with a full wave filter without much of a load.
    Jun 2007
    Mansfield, UK
    I thought about that but decided not to because i was unsure about it leaking back into the output. If a simple diode takes care of it then i guess the rectifier would do the same thing.
    I worked out that witout a capacitor or anything that the PIC could get up to 0.38V less than what it should do. That equates to about 78 levels difference out of 1024 or a 7.6171875% error. All that is based on my maths being correct but 7.6% sounds about right.
    I just had an idea. dhouston mentioned zero-crossing. I already know how to detect that thanks to the PWM circuits ive made before. What i could do is wait for a zero crossing then wait a certain amount of time then run a few samples. That should put all the samples closer to the peak.
    The capacitor idea sounds really simple though. If the capacitor can keep the level high enough between peaks then in theory i could sample each one once every second. I would like a single chip to sample all 8 if possible and send the data to the PC through serial so i think i do really need the capacitor.
    What is the purpose of a "bleed" resistor? Is that to go in series or parallel with the capacitor? I would need the capacitor to empty pretty quick but not as quick as the frequency of the input. I dont want to have to wait 10 mins while it realises the output isnt drawing as much current anymore.
    Edit: I plan to buy an oscilloscope with these components so it will be easier to test and see the sinewave
