Push button on PIC16F887
Results 1 to 22 of 22
    Just a question Menta, why did you set the ports as analogue if you are using them for a switch???
    Quote Originally Posted by gringobomba14 View Post
    They aren't...
    PortA is set for analog...
    PortB is set for digital (ANSELH = 0). The comment behind the line in the code a few posts back is technically correct, but slightly misleading.
    Jun 2008
    Thats right.
  1. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  2. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  3. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  4. push button problem
    Last Post: - 2nd June 2005, 20:44
  5. Push Button 'Menu' to Choose Variable.
    Last Post: - 10th March 2005, 08:00
