Push button on PIC16F887
Results 1 to 22 of 22
    Jun 2008
    Ye, I though about it,
    But I use the button as "Rising Edge" so when the button is pressed there is no interrupt yet.
    Quote Originally Posted by menta View Post
    I didn't say anything about the button causing the interrupt did I?
    If you re-read my post, you'll see that I said that a timer causes an interrupt and the button input is read during that interrupt. Therefore, it doesn't matter if your button pulls a line high or low, or what, as long as you are able to read the state of that pin during the interrupt.
    Jun 2008
    Right,
    Thanks.
    Just a question Menta, why did you set the ports as analogue if you are using them for a switch???
    Quote Originally Posted by gringobomba14 View Post
    They aren't...
    PortA is set for analog...
    PortB is set for digital (ANSELH = 0). The comment behind the line in the code a few posts back is technically correct, but slightly misleading.
    Jun 2008
    Thats right.
  1. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  2. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  3. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  4. push button problem
    Last Post: - 2nd June 2005, 20:44
  5. Push Button 'Menu' to Choose Variable.
    Last Post: - 10th March 2005, 08:00
