Yes...
Put your source file (the file which is your source file, the file you are writing to be compiled/assembled and programmed)
to where the path to that source file (the path being the complete expression of the file itself, for example C:\My Documents\PIC_Source_Code\My_Test_File.PBP)
doesn't exceed 62 characters (the count of the characters in that complete source file path does not exceed 62. The count being less than 62, a number of lesser significance when compared to 62, an amount when compared to 62 comes up short with respect to aforementioned quantity).
I don't know...
Is it english?
Let me try something:
Сложете източник файл, където пътят към този източник на файла не надвишава 62 символа
إسلام أون لاين ملف المصدر الى ان الطريق الى ملف المصدر ان لا تتجاوز 62 حرفا
Put vašeg source file u kojem je put do tog izvora datoteke ne prelazi 62 znakova
Dejte zdrojový soubor, kde se cesta k souboru, že zdroj není vyšší než 62 znaků
Разместите исходный файл, где путь, что исходный файл не превышает 62 символов
Which one works for you?
Well, It must be obvious to one who knows this,.
I tried search for "source file path exeeds 62 characters' which didn't return anything.
I guess I should have search for less words.
I have managed to use the button as interrupt form this source:
http://darreltaylor.com/DT_INTS-14/hello.html
Is it possible also to get another interrupt for the same button while it is pressed for 2 seconds for example ?
IF a timer interrupts every 1/10 second, and you want to look for a button being pressed for 2 seconds, then I'd suggest looking at the button during every interrupt and add 1 to a counter. If the counter hits 20, the button is pressed for 2 seconds. If the button is let up when the counter is below 20, then reset the counter to zero.
Simple enough...
