Skimask- they have R\W hardwired to GND on this board.
Well, Acetronics gets the cookie today.
Adding:
INTCON = 0
ANSEL = 0
ANSELH = 0
Gets what I wanted on the LCD. Can't fix the EasyPic5 example code(yet). First learn how to crawl, then with luck I might be able to stand up.
So far I have been working with 3 different chips, 16F877A, 877, and 84 on two different boards. Should I continue that way or try to focus more on one combination until I get on my feet?
After spending a few nights reading posts here I saw most common problem was getting the darn chip configured and the ports set properly. I figured using 3 different MCUs would give me more chances to learn setting things up or break them as case may be.
I want to Thank all of the members who have responded to my posts, don't give up hope.
I may learn how to read the datasheets. Right now half is in english and the rest is in some ancient dialect that totally escapes me.![]()
If it were me, I'd stick with the 16F887. (also pay attention with the older chips, whether or not they're the A version or not) The 84, 628, and 877 are old school. Nothing wrong with them at all.
The '887 is comparatively new, has a lot of features that the 877(A) doesn't have.
If you get used to the '887, everything it does/has easily translates down to the smaller PICs.
AND...everything the '887 does/has, can be ported to the higher end, faster, bigger, more complex 18Fxxx series.
As an example that I've used a few times with others...I build an MP3 player awhile back, started off with a 16F877A, ran out of code space, plugged in an 18F452 (double the code space), ran out of code space with that, plugged in an 18F4620.......All without physically changing ANYTHING in the circuit, just a few registers here and there needed to be changed.
In addition to that, I started out my latest project with an 18F4620, recently moved up to an 18F4685.
So...in summation:
PIC16F877A = 16K, PIC18F452 = 32K, PIC18F4620 = 64K, PIC18F4685 = 96K.
It's all about the toys![]()
Hi, Manwolf
Want to translate the MKE " LCD Test" you showed ad first post ???
Really Interesting to see the MKB and PbP differences for LCD commands ...
Now, for your LED ... Outputs are BISTABLE ... If you "tell" them to be High ... they stay high !!! ( stupid thing ! )
you also must "tell" them to turn LOW ...
Also remember you can't use LCD on PortB AND the PortB Leds on EasyBoards at the same time ... ( a look at the board scheme will lit your light )
You must use another Port for your Leds ...
A quick tour into PbP Manual seems useful ... you to see how " main" commands work.
