LCD issue with EasyPIC5
Results 1 to 13 of 13
    May 2008
    Florida
    Which PICs do you actually have on hand?
    16F84
    16F628
    16F877
    16F887
    Quote Originally Posted by manwolf View Post
    16F84
    16F628
    16F877
    16F887
    If it were me, I'd stick with the 16F887. (also pay attention with the older chips, whether or not they're the A version or not) The 84, 628, and 877 are old school. Nothing wrong with them at all.
    The '887 is comparatively new, has a lot of features that the 877(A) doesn't have.
    If you get used to the '887, everything it does/has easily translates down to the smaller PICs.
    AND...everything the '887 does/has, can be ported to the higher end, faster, bigger, more complex 18Fxxx series.
    As an example that I've used a few times with others...I build an MP3 player awhile back, started off with a 16F877A, ran out of code space, plugged in an 18F452 (double the code space), ran out of code space with that, plugged in an 18F4620.......All without physically changing ANYTHING in the circuit, just a few registers here and there needed to be changed.
    In addition to that, I started out my latest project with an 18F4620, recently moved up to an 18F4685.
    So...in summation:
    PIC16F877A = 16K, PIC18F452 = 32K, PIC18F4620 = 64K, PIC18F4685 = 96K.
    It's all about the toys
    May 2008
    Florida
    ROFLMAO
    So true, all older chips are A version.
    Thanks for your advise I will focus on the 16F887. Time to break out the old checkbook and get a couple of spares. Guess I might pick up a couple of the 18Fs as well.
    Yep, get to know that '887.
    As far as the 18F, if it was me...I'd grab a couple of 18F4550 (USB) and 18F4685 (lotsa code space + CAN). And if you want the smaller 28 pin package, 18F2550 and 18F2685.
    There are newer ones out there...but I don't have any use for them at the moment so I can't comment on those.
  1. I can not figure out an LCD issue
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 11th March 2010, 14:54
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 09:52
  5. LCD will not start
