LCD issue with EasyPIC5
Results 1 to 13 of 13
    Talking Rtfds ...
    Hi, Manwolf
    The '887 has ANALOG pins on PortB ... I believe.
    sooooooo ....
    I miss something in your listing.
    PS: I already saw that on a ME "C" Forum ... LoL !!! ( you're not the only one !!! )
    Mar 2004
    UK-Midlands
    Hi Manwolf,
    When using their hex files with their programming software (PicFlash) it somethines uses default fuses.
    Check oscillator is set to HS not 'XT' on the programming software?
    Also the link settings on the board are set ok?
    The suplied hex file works ok on my EP5
    Bob
  1. I can not figure out an LCD issue
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 11th March 2010, 14:54
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 09:52
  5. LCD will not start
