Newbie needs help
Results 1 to 10 of 10
    Jun 2008
    Hot damn! That was quick thinkin! You just blew my mind...
    hehe, thanks dude!
    Is that common practice? Or would interrupts be used for something like that ever?
    www.theLanguageBear.com - Multi-Lingual books for kids and adults of all skill levels.
    Quote Originally Posted by chien_fu View Post
    Totally your call...
    Jun 2008
    Default Reign in the randomness
    Next question...
    I'm trying to generate a random number between X and Y...
    The only command I see is:
    Random Var
    And the manual says it generates numbers up to 65,000
    Is there a way to reign this bugger in a bit?
    Next question...
    Random Var
    Turn on your outside the box thinking...
    If the number is too big, don't use it.
    If the number is too small, don't use it.
    If the number is below the lower limit of what you want, or above the upper limit of what you want, then DON'T USE IT.
    Jun 2008
    That's what I've got going now...
    Randomizer:
    RANDOM rand
    high 3 : pause 10 'Blinks an LED once per random number generated
    low 3 : pause 10
    IF rand > 100 THEN Randomizer
    IF rand < 1 THEN Randomizer
    but the "random" numbers just seem to get larger and larger. After rand > 100 it just goes into a vicious blinking cycle, never to return.
    Randomizer:
    RANDOM rand
    low 3 : pause 10
    What does your manual say about random, specifically the last sentence in the section about RANDOM?
    And what is the answer to 65535/655 ?
    Can you do anything at all with that?
    Jun 2008
    I see the thread paused for a bit, so I thought I'd twist my head around this and suggest setting rand to 0 before running the randomizer every time, otherwise it'll use the existing rand-value as seed and thus just grow?
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 18:45
  2. Newbie HELP :(
    By TheOne in forum mel PIC BASIC
    Last Post: - 27th March 2009, 18:15
  3. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 10:56
  4. PIC Newbie
    By azmax100 in forum Schematics
    Last Post: - 23rd February 2007, 05:52
  5. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 10:01
