Newbie needs help
Results 1 to 10 of 10
    Jun 2008
    Red face Newbie needs help
    So, I'm very new to this, bare with me... I have a loop statement going and going and going.. as follows: (just a 10sec interval flashing LED)
    loop:
    High 0
    Pause 10000
    Low 0
    Pause 10000
    Goto loop
    And I want to interrupt this loop with a button push, more importantly a button hold, (2sec). So when you hold the button it pops out of its loop.
    Don't really know where to start with this... as far as I can tell I can only check the button state (up/dn) once per loop?
    Thanks for your patience..
    www.theLanguageBear.com - Multi-Lingual books for kids and adults of all skill levels.
    Quote Originally Posted by chien_fu View Post
    Then don't do one 10-second pause, do 5 2-second pauses....
    Or 10 1-second pauses. If the button is held for 2 consecutive pauses, then kick out of the loop.
    Jun 2008
    Hot damn! That was quick thinkin! You just blew my mind...
    hehe, thanks dude!
    Is that common practice? Or would interrupts be used for something like that ever?
    Totally your call...
    Jun 2008
    Default Reign in the randomness
    Next question...
    I'm trying to generate a random number between X and Y...
    The only command I see is:
    Random Var
    And the manual says it generates numbers up to 65,000
    Is there a way to reign this bugger in a bit?
    Next question...
    Random Var
    Turn on your outside the box thinking...
    If the number is too big, don't use it.
    If the number is too small, don't use it.
    If the number is below the lower limit of what you want, or above the upper limit of what you want, then DON'T USE IT.
  1. Newbie making an ignition timer
    Last Post: - 5th August 2012, 18:45
  2. Newbie HELP :(
    By TheOne in forum mel PIC BASIC
    Last Post: - 27th March 2009, 18:15
  3. Newbie: Temperature measurements
    By Budda in forum General
    Last Post: - 30th March 2007, 10:56
  4. PIC Newbie
    By azmax100 in forum Schematics
    Last Post: - 23rd February 2007, 05:52
  5. request for a newbie forum
    By nimonia in forum Forum Requests
    Last Post: - 20th May 2006, 10:01
