Replacing existing pic
Results 1 to 30 of 30
    Mar 2006
    China
    Default Why not a mouse sensor
    Why not attach a sensor with encoder from an old PC mouse on the end of the rotating axis. Then you can count how many pulses and position your screen within mm from where it should be.
    You might even have a pin on your pic to a hardware counter and then it will more or less count by itself.
    /me
    Quote Originally Posted by Jumper View Post
    I thought about that too...but, if that count goes off by one this time, one the next time, and so on, one of those times, the motor is gonna drive too far, burn out, the screen is going to fall off, whatever. Still need some sort of end of travel sensor to reset the counter to zero (or 100 or whatever) once in awhile to keep things straight.
    May 2008
    Actually the motor has it's own cut-out
    When the screen is fully extended it kills the motor, and when it's fully retracted it does the same. That's built in the head end. The worse that'll happen is it'll extend to far for my use and knock something off the TV unit
    I did consider it, and still haven't ruled it out (as a mouse is cheaper then my parts order - and I should have one laying around)
    But I have questions like - how do I count without causing the remote to fail, or while still being able to respond on the serial port. - If I remember right
    one of these timer/pwm/things/ works as a counter also - perhaps I can let it do the counting in the background and interrupt when it overflows.
    I suppose it's one of those things I'd have to experiment with.
    The option is open for a combination of the two.
    A sensor at the top to tell it when it's fully retracted, and using the mouse sensor to count the way down.
    But, just knowing absolutely whether the screen is UP or DOWN will be so much easier.
    My biggest problem now comes from being completely broke and not being able to afford the parts I need to make sensors.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replacing Hall Effect throttle with PIC
    By idtat in forum General
    Last Post: - 22nd October 2009, 22:55
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  4. Replacing shift register with PIC
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 7th April 2008, 19:31
