Replacing existing pic
Results 1 to 30 of 30
    If a pin varies a little, it may be changing state faster than the device you are trying to measure it with. I would think the code is doing something with the weak pull-ups on the pins. Fiddling with the weak pull-ups would allow the chip to scan the buttons, and the code may even use the ADC to read pin levels.
    Tim Barr
    Sure enough they use internal pull-ups. Make sure you disable the ADCs and comparators before.
    Now how to know which push button.. Are you sure of the current schematic? Any way it miss some resistors and/or diode in that?
    May 2008
    I'm positive there's no missed resistors or diodes in relation to the push buttons - as much as it's a very abbreviated schematic, the circuit really doesn't have much more - I can upload some scans of the board if you like, but I've actually decided to approach this a different way.
    Originally I was going to sacrafice the remote control function to gain a serial interface, but what I've since decided to do is take the two outputs from the original pic and feed it into another pic - this will give me my serial interface and keep the remote control - without having to deal
    Now I have a problem with frightfully slow interrupts - I've tested this in PIC Simulator and it works reasonably quickly there. In real life tho, this code interrupts 'eventually' usually 5-20 seconds later. I can't see why, I'm only tying it up for 10 ms then I've inserted an extra pauseus so it's got something to interrupt before/after before returning to serin.
    Anyway I can speed up the interrupt to... between 11 and 100 ms?
    ' Configure the pic
    @     device pic12F675, INTRC_OSC_NOCLKOUT, WDT_ON, PWRT_ON, MCLR_OFF, BOD_ON, CPD_OFF, PROTECT_OFF
    N9600   CON     6
    CMCON        = 7
    ANSEL        = 0
    Relay1       VAR GPIO.5
    Relay2       VAR GPIO.4
    SlavePower   VAR GPIO.2
    SlaveRelay1  VAR GPIO.0
    SlaveRelay2  VAR GPIO.1
    Serial       VAR GPIO.3
    B0           var BYTE
    INPUT SlaveRelay1
    INPUT SlaveRelay2
    INPUT Serial
    OUTPUT Relay1
    OUTPUT Relay2
    OUTPUT SlavePower
    ON INTERRUPT GOTO slaveSpeaks
    IOC            = %00000011
    INTCON       = %10001000
    ' Turn on the original PIC
    HIGH SlavePower
        B0 = 0
        PAUSEUS 1
        SERIN Serial, N9600, 10, main, [1], B0
        ' The original PIC latches it's output, we want to reboot the original pic if we get something from the serial port to force it's outputs low
        IF B0 > 1 THEN LOW SlavePower
        if B0 = 2 THEN GOSUB subUp
        IF B0 = 3 THEN GOSUB subDown
        IF B0 = 4 THEN GOSUB subStop
        IF B0 > 1 THEN
            PAUSEUS 1000
            HIGH SlavePower
    GOTO main
    DISABLE
    subUp:
        LOW Relay2
        HIGH Relay1
    subDown:
        LOW RELAY1
        HIGH Relay2
    subStop:
        LOW Relay1
        LOW Relay2
    slaveSpeaks:
        if SlaveRelay1 THEN
            GOSUB subUp
            IF SlaveRelay2 THEN
                GOSUB subDown
                GOSUB subStop
        INTCON = %10001000
        RESUME
    ENABLE
    I would probably skip the interrupt and perform everything in a tight loop instead. As the Relay check is done pretty quick. Not a fan of using GOSUBs in a ISR.
    From what i feel, S2 should have dual contacts attach to GPIO<1:0>
    To know which relay is activated, i would bet that...
    WhichRelay VAR BYTE
    WhichRelay=GPIO & 3
    Select case WhichRelay
        CASE 0 ' Relay 2
          ' do stuff for relay 2
        CASE 1 ' Relay 1
          ' do stuff for relay 1
        CASE 2 ' Relay 3
          ' do stuff for relay 3
         END SELECT
    If you still want to use Ints, don't re-enable the GIE bit, the PIC will do it for you. Just clear the offending INT flag and get out of there.
    If you play with GIE bit, you will run into problems, that's for sure.
    May 2008
    Heh, never even thought about SELECT CASE
    So something more like this then.
    ' Configure the pic
    N9600   con     6
    CMCON        = 7
    ANSEL        = 0
    Relay1       VAR GPIO.5
    Relay2       VAR GPIO.4
    Serial       VAR GPIO.3
    B0           var BYTE
    SlaveState   VAR BYTE
    WhichRelay   VAR BYTE
    INPUT SlaveRelay1
    INPUT SlaveRelay2
    INPUT Serial
    OUTPUT Relay1
    OUTPUT Relay2
    OUTPUT SlavePower
    restart:
    SlaveState = 0
    PAUSEUS 1000
    HIGH SlavePower
        B0 = 0
        pauseus 1
        if B0 == 2 THEN GOSUB subUp
        IF B0 == 3 THEN GOSUB subDown
        IF B0 == 4 THEN GOSUB subStop
        IF B0 > 1 THEN GOTO restart
        WhichRelay = GPIO & 3
        IF SlaveState <> WhichRelay THEN
            SlaveState = WhichRelay
            SELECT CASE WhichRelay
                CASE 0
                    GOSUB subStop
                CASE 1
                    GOSUB SubUp
                Case 2
                    GOSUB subDown
            END SELECT
    subUp:
        LOW Relay2
        HIGH Relay1
    subDown:
        LOW RELAY1
        HIGH Relay2
    subStop:
        LOW Relay1
        LOW Relay2
    May 2008
    Oh I feel like such an idiot - Note to self, double check the label in 'serin' if you change your code substantially...
    ' Configure the pic
    N9600   con     6
    CMCON        = 7
    ANSEL        = 0
    Relay1       VAR GPIO.5
    Relay2       VAR GPIO.4
    Serial       VAR GPIO.3
    B0           var BYTE
    SlaveState   VAR BYTE
    WhichRelay   VAR BYTE
    INPUT SlaveRelay1
    INPUT SlaveRelay2
    INPUT Serial
    OUTPUT Relay1
    OUTPUT Relay2
    OUTPUT SlavePower
    restart:
    SlaveState = 0
    PAUSEUS 1000
    HIGH SlavePower
        B0 = 0
        SERIN Serial, N9600, 15, testSlave, [1], B0
        LOW SlavePower
        SELECT CASE B0
            CASE 2
                GOSUB subUp
            CASE 3
                GOSUB subDown
            CASE 4
                GOSUB subStop
        END SELECT
        GOTO restart
    testSlave:
                CASE 0
                    GOSUB subStop
                CASE 1
                    GOSUB SubUp
                Case 2
                    GOSUB subDown
            END SELECT
    subUp:
        LOW Relay2
        HIGH Relay1
    subDown:
        LOW RELAY1
        HIGH Relay2
    subStop:
        LOW Relay1
        LOW Relay2
    May 2008
    Nope, that isn't working either.
    It's working in the simulator but not in the real life.
    Should I set up pulldown resistors on the inputs of the new pic from the outputs of the old pic?
    This should work. The only thing i would suggest you, is to use a slower baudrate, check the manual for that. They suggest higher speed OSC for 9600 bauds.
    Maybe not a bad idea to call the OSCCAL value to make sure you use the factory calibration for the internal OSC.
    DEFINE OSCCAL_1K 1
    Your code don't enable the internal pull-up
    OPTION_REG.7=0
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replacing Hall Effect throttle with PIC
    By idtat in forum General
    Last Post: - 22nd October 2009, 22:55
  3. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  4. Replacing shift register with PIC
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 7th April 2008, 19:31
