My Idea is to capture frome some Digital Kamera a Picture and than to Read with the Microcontroller and to send via Gprs Modem.
regards Pesti
regards Pesti
A file is a file. Whether a .jpg, or text, you need to know where it is, how long it is, and the destination. You need horsepower, and 32 bit math. I sent pictures from an SD card, to an SD card wirelessly. It took a while at 115Kbaud. GMRS has limited bandwidth.
I think,
if you mange it to read out the ccd and you know what system will work on the "end" of the GPRS-connection, then it will be easy to find a simple protocol you can use.
So, do your homework and try to make clear, what you want to do.
1-2 Months.
I need this for a Elevator,I have in the Elevator a Security system that is connectd with a GPRS Modem.
When someone Push the SOS Button then I make a single Picture shot and then I send the Data to the Security Center to see what is wrong .
The Problem is that I dont know what Digital Camera should I use for this Project.
Regards Pesti
Sorry but I dont understand what you mean with average! :-)
Regards Pesti
