Sending Images to RS232
Results 1 to 15 of 15
    Bombay, India
    I will second BigWumpus on the protocol part. However if you are not game to do it that way, you can take a chunk of 16 bytes, checksum it and send. When received, ack/nak the chunk to decide whether to move on. This may be far simpler to implement.
    My Idea is to capture frome some Digital Kamera a Picture and than to Read with the Microcontroller and to send via Gprs Modem.
    regards Pesti
    Quote Originally Posted by Pesticida View Post
    How long do ya suppose this will take?
    Sep 2003
    Vermont
    A file is a file. Whether a .jpg, or text, you need to know where it is, how long it is, and the destination. You need horsepower, and 32 bit math. I sent pictures from an SD card, to an SD card wirelessly. It took a while at 115Kbaud. GMRS has limited bandwidth.
    Something between 10-40 Seconds Sending and ~ 80 KB.
    For the moment I want to use this Resolution 640X480 Pixel.
    Regards Pesti
    Hangover, Germany
    Exclamation
    I think,
    if you mange it to read out the ccd and you know what system will work on the "end" of the GPRS-connection, then it will be easy to find a simple protocol you can use.
    So, do your homework and try to make clear, what you want to do.
    Regards Pesti
    What I meant was...how long to finish said project...
    1-2 Months.
    I need this for a Elevator,I have in the Elevator a Security system that is connectd with a GPRS Modem.
    When someone Push the SOS Button then I make a single Picture shot and then I send the Data to the Security Center to see what is wrong .
    The Problem is that I dont know what Digital Camera should I use for this Project.
    Regards Pesti
    Sep 2003
    Vermont
    What is the average, not maximum data rate for the GPRS modem?
  1. Universal remote and Rs232
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 7th February 2010, 17:55
  2. UART vs software RS232
    Last Post: - 5th September 2008, 18:27
  3. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 13:33
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  5. Sending data over USB via VB
    Last Post: - 12th September 2005, 01:00
