LCD Problem
Results 1 to 16 of 16
Thread: LCD Problem
    Aug 2005
    Default LCD Problem
    I’ve got a 20 line 4 row alphanumeric display wired to a PIC18F252 using the default pins. On line 1 im displaying 20 characters, which displays ok, but the problem is the 13th to the 20th characters from the first line is displaying on line 2.
    Thanks Sphere.
    '---------------------------18F252 RUNNING AT 20Mhz-----------------------------
    @CONFIG_REQ
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    @ __CONFIG _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    @ __CONFIG _CONFIG3H, _CCP2MX_OFF_3H
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    @ __CONFIG _CONFIG2L, _BOR_OFF_2L & _BORV_42_2L & _PWRT_ON_2L
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    DEFINE OSC 20
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 4
    adcon1=7
    PAUSE 500
    lcdout $FE,1
    lcdout $FE,$80,"THIS IS A TEST LINE1" 'LINE 1
    MAIN:
    pause 4000
    GOTO MAIN
    Sep 2003
    Vermont
    How about this, I believe that the $C0 is the beginning of the second line.
    PAUSE 500
    lcdout $FE,1,"THIS IS A TEST LINE1" 'LINE 1
    lcdout $FE,$C0,"This should be line2"
    MAIN:
    pause 4000
    GOTO MAIN
    Aug 2005
    This is what shows on lines 1&2 on the display:
    ST LINE1
    Using the lcdout $FE,$C0,"This should be line2" shows on lines 3&4 on the display just like this:
    be line2
    Ive use other 20x4 lcd displays in the past with no problems.
    Thanks Sphere.
    Hi Sphere,
    Here is what I would do to troubleshoot: Change the comment on line 1 so you can tell if
    it is scrambling the comment and printing it or if it is simply printing the last 8 characters
    of line 1 on line 2. It maybe you will have to define commandus and Dataus for this particular LCD
    Aug 2005
    Ive altered LCD_COMMANDUS & LCD_DATAUS from one extreme to another and I either get nothing on the display, corrupt display or the same result as before.
    Would wiring all of the data pins on the lcd make a difference or have I just got a duff lcd.
    Thanks Sphere.
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Have you included a defines list like below?
    Note the lines define in the 10th line should be for 4 lines
    Define LCD_DREG PORTb ' Port for LCD Data
    Define LCD_DBIT 4 ' Use upper 4 bits of Port
    Define LCD_RSREG PORTb ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 0 ' Port Pin for RS bit
    Define LCD_EREG PORTb ' Port for Enable (E) bit
    Define LCD_EBIT 2 ' Port Pin for E bit
    DEFINE LCD_RWREG PORTb 'port for the R/W bit
    DEFINE LCD_RWBIT 1 'port pin for R/W bit
    Define LCD_BITS 2 ' Using 4-bit bus
    Define LCD_LINES 4 ' Using 4 line Display **************************
    Define LCD_COMMANDUS 2000 ' Command Delay (uS)
    Define LCD_DATAUS 50 ' Data Delay (uS)
    Peter Moritz.
    New South Wales,
    Australia.
    Quote Originally Posted by Sphere View Post
    Keep in mind that LCD_DATAUS is a byte value. Max is 255. 256 would be treated just like a 0. LCD_COMMANDUS is still a word value.
    Of course wiring would make a difference.
    Looks to me like you've got some crossed wires and/or solder joints.
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 08:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 19:48
  3. LCD problem
    By Andre_Pretorius in forum General
    Last Post: - 27th January 2009, 15:47
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  5. Need help with LCD number display.
