Mister-e '..Is there any exact motor Model we can refer to?..'
There are no markings on the motors. The original controller used a 6v battery pack, and the coil resistance is 18ohm. A similar looking motor is the BPM42 from Astrosyn, but that is specified as 12v.
Joe S. - thanks for joining the party! i would be happy to rewrite the code in Basic if that would help, but I think the code is working. I programmed the PIC on a Vellerman 8048 unit, which has a limited test function (6 leds and 4 switches), and the test showed the leds all lighting up at the right times. I have also run the code on a couple of software simulators, and it does what it says it does - holds the specified pins high.
What I cannot simulate is what the L293D is doing (no oscilloscope). In other circuits I see the possibility of varying the current passed to the stepper, but I don't think you can on the L293D. How does the chip know how much current to pass the stepper?
The Lini Stepper is very interesting, and I would buy one like a shot - if it supported Bipolar steppers like I have on the telescope. Unfortunately, the telescope hardware is fixed. I was wondering about getting one of these - http://www.jafmotion.co.uk/motordrives.htm
