FREQOUT compiler error on USB Pic
Results 1 to 26 of 26
    How did you know that i should do that?
    The warning message tells you where the problem is. Warning[202] \PBP\PBPPIC18.LIB 1239
    I looked in the library at the line # indicated by the warning message. In v2.50a there was no problem. In v2.47 this was missing, so it's a simple fix to get rid of the warning.
    It also helps if you know assembler...;o]
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Ya know, I never made the correlation between the 'PBPPIC18.LIB' and the '1239' in the error messages. I always did it the hard way described above.
    Thanks for the tidbit...
    Mar 2008
    Ohh, it's because i have PBP 2.46!
    It may go back a few versions, but I didn't check back any farther than 2.47.
    -Bruce
    tech at rentron.com
    Quote Originally Posted by mindthomas View Post
    $25 for the upgrade...
    Mar 2008
    To what, 2.50?
    To what, 2.50?
    Yep, 2.50, 32 bit signed variables and a few other upgrades...
    Good stuff in my book...
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 19:44
  3. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 13:00
  4. Replies: 15
    Last Post: - 30th October 2007, 20:25
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
