Lookup Table
Results 1 to 7 of 7
Thread: Lookup Table
    Default Lookup Table
    Hi anyone. I want to make a lookup table in my program. At the first I wanted to make it with LOOKUP. But I want to use program memory instead of RAM. So I think
    that LOOKUP instruction can't help me in this regard! I make this lookup table in asm:
    TABLE
    ADDWF 02,1
    RETLW 0X01
    RETLW 0X02
    RETLW 0X04
    RETLW 0X08
    RETLW 0X10
    RETLW 0X20
    RETLW 0X40
    RETLW 0X80
    I recall table with CALL TABLE. Unfortunately it doesn't work. Why? What should I do? Thanks for helpful replies.
    PEEKCODE and POKECODE should do it nicely ... just read the manual ...
    Feb 2003
    Salt Lake City, Utah USA
    also find this excellent thread started by Melanie
    "Making Program Code Space your playground"
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Hi yasser,
    What precisely are you trying to do? PBP does not use RAM to create lookup tables except for the index & result variables.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Unhappy Peek, Poke, DB, ASM ...?
    Hi and thanks for your replies. I visited above links. I want to save data on program memory space and send them to LEDs byte by bytes. This is a part of my program:
    Send:
    StrAddr = $370
    for j = 0 to 2
    CharAddr = StrAddr + (80*j)
    for k = 0 to 79
    PeekCode CharAddr+k, x
    GOSUB DISPLAY
    next k
    next j
    Send_Back:
    StrAddr = $460
    for j = 2 to 0 step -1
    for k = 79 to 0 STEP -1
    GOSUB DISPLAY
    next k
    next j
    ' Introduction of Image *
    @ org 370h
    Pokecode $00,$00,$00,$00,$01,$01,$01,$03,$00,$00,$00,$00,$0 1,$01,$01,$03,$00,$00,$00,$00,$01,$01,$01,$03,$00, $00,$00,$00,$01,$01,$01,$03,$00,$00,$00,$00,$01,$0 1,$01,$03,$00,$00,$00,$00,$01,$01,$01,$03,$00,$00, $00,$00,$01,$01,$01,$03,$00,$00,$00,$00,$01,$01,$0 1,$03,$00,$00,$00,$00,$01,$01,$01,$03,$00,$00,$00, $00,$01,$01,$01,$03
    It doesn't work. Why?
    Can you tell me about DB usage? How can I use it? I used ASM code (as I said above). Why didn't it work correct?
    Thanks alot
  1. Lookup table syntax.....
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 19th May 2009, 05:45
  2. Lookup table or Math?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2008, 18:55
  3. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  4. Need help with lookup table or direct calculation
    By nverma in forum mel PIC BASIC Pro
    Last Post: - 11th October 2006, 19:27
  5. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
