FREQOUT compiler error on USB Pic
Results 1 to 26 of 26
    Mar 2008
    Default FREQOUT compiler error on USB Pic
    I have now got my USB Project working, and i am now working with some sound! (I needed to Comment out some lines in the 18F2550.INC file)
    But now when i use FREQOUT command in my USB script i get this error:
    "Warning[202] \PBP\PBPPIC18.LIB 1239: argument out of range. least significant bits used."
    I don't know what it is, but i think it's somthing with a kind of config!
    Quote Originally Posted by mindthomas View Post
    Generally, it means you're trying to stuff a WORD variable into a BYTE register.
    Mar 2008
    Ohh, but why? The code line is this:
    FREQOUT buzzer,1000,2000	'Freq=262 Hz
    Open your pbppic18.lib and scroll down to line number 1239. Where you see addlw (sintable) change it to addlw low(sintable)
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce, What version of PBP do you have there? I just checked my latest version w/patch and find no instance of this.
    Hi Dave,
    I have the latest version + I keep all older versions for tech support. v2.47 is the version
    I noticed the low missing in. It works even without the mod, but always returns the warning.
    -Bruce
    tech at rentron.com
    Mar 2008
    Thanks.. It worked, and how did you know that?
    Another thing, how can i put two bytes together, because i need to select the FREQUENCE with USB, but i can only go up to 255, so how can i make so i can send a higher value?
    Word, highbyte, lowbyte, byte1, byte0, and so on...
    It's all in the book...
    Mar 2008
    How did you know that i should do that?
    Just want to know if it happends again.
    If you've got MCS setup to dump out a .lst file with all the options turned on (usually fairly HUGE files), you can usually scroll thru it or search it for the phrase 'ERROR', then using a bit of deductive logic, can usually trace that back to your original problem...whether it be a problem with the typist, an include file, a macro, whatever.
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. need help! to beginner
    By emilhs in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 19:44
  3. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 13:00
  4. Replies: 15
    Last Post: - 30th October 2007, 20:25
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 18:39
