How On Interrupt works?
Results 1 to 13 of 13
    You're welcome, but you'll want to consider a few other things here too.
    1. RCIF is only cleared after a read of RCREG. To clear RCIF, you will want to read this data
    with HSERIN or X = RCREG until RCIF is cleared.
    2. Values you use in hardware USART defines are not loaded into USART registers if there is
    not at least one instance of HSERIN or HSEROUT used somewhere within your program.
    Just inserting these defines is not configuring the hardware USART for you. Just FYI.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hi Bruce,
    That's good info! Thanks, How is that book coming? Sign me up for a copy
    JS
    Where in the Picbasic Manual can I get more info on what <b>INTCON</b> means and how to determine its value?
    Thank you
    Koossa
    Here is my new code, but still the RX LED does not work.
    <hr>
    <b>Code for TX</b>
    <hr>
    <code>
    &nbsp;&nbsp;Include "Modedefs.bas"
    &nbsp;&nbsp;DEFINE&nbsp;&nbsp;&nbsp;&nbsp; OSC 4
    &nbsp;&nbsp;DE_OR_RE&nbsp;&nbsp;&nbsp;&nbsp;VAR PORTC.5&nbsp;&nbsp;&nbsp;&nbsp; ' DE and RE Pin of SN75176
    &nbsp;&nbsp;LEDPIN&nbsp;&nbsp;&nbsp;&nbsp; VAR PORTD.2&nbsp;&nbsp;&nbsp;&nbsp; ' LED to confirm PIC is running
    &nbsp;&nbsp;DATARECEIVED&nbsp;&nbsp;VAR BYTE
    &nbsp;&nbsp;
    &nbsp;&nbsp;'======== HSEROUT, HSERIN SETTINGS ==========
    &nbsp;&nbsp;DEFINE HSER_RCSTA 90h
    &nbsp;&nbsp;DEFINE HSER_TXSTA 24h
    &nbsp;&nbsp;DEFINE HSER_BAUD 9600
    &nbsp;&nbsp;ADCON1 = 7
    &nbsp;&nbsp;RCIF&nbsp;&nbsp;VAR&nbsp;&nbsp;PIR1.5& nbsp;&nbsp;&nbsp;&nbsp;' Alias RCIF (USART Receive Interrupt Flag)
    &nbsp;&nbsp;OERR&nbsp;&nbsp;VAR&nbsp;&nbsp;RCSTA.1 &nbsp;&nbsp;&nbsp;&nbsp;' Alias OERR (USART Overrun Error Flag)
    &nbsp;&nbsp;CREN&nbsp;&nbsp;VAR&nbsp;&nbsp;RCSTA.4 &nbsp;&nbsp;&nbsp;&nbsp;' Alias CREN (USART Continuous Receive Enable)
    &nbsp;&nbsp;
    &nbsp;&nbsp;HIGH DE_OR_RE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Make ready for RX
    &nbsp;&nbsp;HSEROUT ["1"]&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;&nbsp;&nbsp;&nbsp; ' Send R1
    &nbsp;&nbsp;HIGH LEDPIN
    &nbsp;&nbsp;PAUSE 5000
    &nbsp;&nbsp;LOW LEDPIN
    GOTO MAIN
    </code>
    <hr>
    <b>Code for RX</b>
    <hr>
    <code>
    &nbsp;&nbsp;DE_OR_RE&nbsp;&nbsp;&nbsp;&nbsp;VAR PORTC.5&nbsp;&nbsp;&nbsp;&nbsp; ' DE and RE Pin of SN75176 (RS485)
    &nbsp;&nbsp;LEDPIN&nbsp;&nbsp;&nbsp;&nbsp; VAR PORTD.2&nbsp;&nbsp;&nbsp;&nbsp; ' LED Pin
    &nbsp;&nbsp;i&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbs p; VAR BYTE
    &nbsp;&nbsp;'======== HSEROUT, HSERIN SETTINGS ==========&nbsp;&nbsp;
    &nbsp;&nbsp;LOW DE_OR_RE&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&n bsp;&nbsp;&nbsp;' Make ready for RX
    &nbsp;&nbsp;INTCON = %11000000&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp ;&nbsp;&nbsp;&nbsp; ' Enable interrupts
    &nbsp;&nbsp;ON INTERRUPT GoTo SerialDataReceived ' Declare interrupt handler routine
    &nbsp;&nbsp;PIE1.5 = 1&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; ' Enable interrupt on USART
    DoSomeStuff:
    &nbsp;&nbsp;For i = 0 to 10
    &nbsp;&nbsp;&nbsp;&nbsp;Pause 2
    &nbsp;&nbsp;Next i
    &nbsp;&nbsp;GOTO DoSomeStuff
    &nbsp;&nbsp;DISABLE&nbsp;&nbsp;
    SerialDataReceived:&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;& nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nb sp;&nbsp;&nbsp;' Buffer the character received
    &nbsp;&nbsp;HSerin [DATARECEIVED]&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp ;' Read USART and store character to next empty location
    &nbsp;&nbsp;GOSUB BLINK
    &nbsp;&nbsp;IF RCIF Then SerialDataReceived
    &nbsp;&nbsp;RESUME
    &nbsp;&nbsp;ENABLE
    &nbsp;&nbsp;
    &nbsp;&nbsp;
    BLINK:
    &nbsp;&nbsp;PAUSE 1000
    &nbsp;&nbsp;RETURN
    </code>
    Information on INTCON will be found in the PIC data sheet. Not your PBP manual.
    Do NOT GOSUB to another routine outside the DISABLE / ENABLE block in your interrupt handler.
    After the ENABLE, PBP begins placing more code to jump to the interrupt check routine. So what happens is you jump out to BLINK, you land smack on code that sees the interrupt has not been serviced, and bingo, you're sent right back to SerialDataReceived before code in the BLINK routine can execute.
    Keep all code in your interrupt handler in the protected area between the DISABLE/ENABLE block, or simply remove ENABLE. If SerialDataReceived and BLINK are the last routines in program memory, then you don't even need the ENABLE. This tells PBP to start inserting code before & after each PBP statement to test for the interrupt condition.
    Try this;
     DISABLE
    SerialDataReceived:                ' Buffer the character received
      HSerin [DATARECEIVED]        ' Read USART and store character to next empty location
      HIGH LEDPIN
      PAUSE 1000
      LOW LEDPIN
      PAUSE 1000
      RESUME
    -Bruce
    tech at rentron.com
    Thank you very much Bruce!!!
    It is working now!!!
    Thank you very much for your help Bruce!!!!
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 02:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  4. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
    Last Post: - 6th March 2005, 01:07
