I2C with External Eeprom
Results 1 to 16 of 16
    Default I2C with External Eeprom
    Hi all,
    The reason for this post is that i'm trying to get my 24LC512 eeprom to work with my PIC16F88.
    I was successful with this eeprom and a PIC12F675, but for some reason with the 16F88 i cant read nor write anything.
    I've search the forum for an answer but nothing worked.
    I've read the pic16F88 datasheet over and over and i came up with some doubts.
    Please try to answer my questions so i can proceed in finding a solution
    According to the pic 16F88's datasheet ( I2C )Pin RB1 is for SDA and pin RB4 is for SCL.
    1st question:
    Is it mandatory that i use these ports to communicate with the eeprom ?
    ( this may be a silly question but for 12F675 i can use almost any pin for them ).
    In the datasheet i have found that we need to clear SSPEN bit and program the 2 I2C ports as inputs.
    2nd question:
    For that to happen i need to mess with the SSPSTAT and SSPCON ?
    If yes, can you please show me how can these be set ( since i dont understand the meaning of their bits )
    thanks
    Quote Originally Posted by ruijc View Post
    Hi all,
    1st question:
    2nd question:
    thanks
    You seem to have a bit of a problem with a little bit of everything, but then, that's why you're here...
    PBP's I2C commands pretty much take care of everything for you, no extra work needed, with most chips.
    First off, do you have pull up resistors on SDA/SCL like the manual shows?
    Second...where's the code?
    Sep 2007
    USA, CA
    If you are trying to use the hardware i2c, the 16F88 can't do it--it does not have master i2c capability (only SPI). Therefore, the i2c pin selections are irrelevant--you can connect them anywhere you want, and you'll have to define where they are, and use i2c commands.
    Hello skimask and thanks for your help
    Yes...i have the 4k7 pull ups ( also tryed other resistor values with no success.
    here is the code :
    SSPCON.5 = 0                ; Disable SSP Module
    TXSTA.5 = 0                 ; Disable AUSART Tx
    RCSTA.7 = 0                 ; Disable Serial Port
    OSCCON          = %01111110 'Internal RC w/ I/Os
    INTCON=0
    PIE1     = 0
    'PIE2    = 0
    PIR1                 = 0                   'off
    CMCON= 7
    CVRCON= 0                   'Vref Off
    CCP1CON= 0
    T1CON= 0
    'T2CON = %00000100
    'DEFINEs
    @ DEVICE INTRC_OSC
    @ DEVICE MCLR_OFF
    @ DEVICE PROTECT_OFF
    DEFINE osc 4
    @ DEVICE CPD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE BOD_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE WDT_OFF
    'ADC
    DEFINE ADC_BITS 10 ' Set number of bits in result ( 8 or 10 bits )
    DEFINE ADC_CLOCK 3 ' Set clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    'ADC parameters
    ADCON1  =%10000000      'right justify
    ANSEL   =%00000101
    ADCON0  =%11000001
    INCLUDE "modedefs.bas"
    'settings for serial comm
    DEFINE debug_reg PORTA
    DEFINE debug_bit 1
    DEFINE debug_baud 9600
    DEFINE debug_mode 1
    'I/O's
    PORTA=0
    PORTB=0
    TRISA=%00100101
    TRISB=%00000011
    'PINS
    temp    var PORTA.0
    out     var PORTA.1
    volt    var PORTA.2
    a3      var PORTA.3
    A4      var PORTA.4
    but1    var PORTA.5
    led2    var PORTA.6
    led1    var PORTA.7
    but2    var PORTB.0
    but3    var PORTB.1
    SCL     var PORTB.2
    SDA     var PORTB.3
    green    var PORTB.4
    red       var PORTB.5
    led4      var PORTB.6
    led3      var PORTB.7
    ' variables
    va       var word
    va2      var word
    tempe    var word
    volte    var word
    mem      var byte
    p1a      var word
    p1b      var word
    p2a      var word
    p2b      var word
    p3a      var word
    p3b      var word
    p4a      var word
    p4b      var word
    state   var byte
    st      var word
    ed      var word
    ADDR    var word
    m1      var  byte
    m2      var byte
    m3      var byte
    m4      var byte
    slot    var bit
    w       var byte
    CTW     VAR BYTE
    km      var byte
    ra      var word
    set1    VAR BYTE
    set2    VAR BYTE
    rm      var byte
    x       var byte
    CLEAR
    mem=1
    state=1
    p1a=$10
    p1b=$1070
    p2a=$1080
    p2b=$2140
    p3a=$2160
    p3b=$3220
    p4a=$3230
    p4b=$4290
    start:
    high out
    debug $0D, $0A
    PAUSE 50
    CTW=$A0
    debug "start menu",13,10
    startmenu:
    I2CREAD SDA,SCL,CTW,1,[m1]
    I2CREAD SDA,SCL,CTW,2,[m2]
    I2CREAD SDA,SCL,CTW,3,[m3]
    I2CREAD SDA,SCL,CTW,4,[m4]
    if (mem=1) and (m1=0) then
    led1=1
    led2=0
    led3=0
    led4=0
    slot=0
    if (mem=1) and (m1<>0) then
    pause 300
    toggle led1
    led2=0
    led3=0
    led4=0
    slot=1
    if (mem=2) and (m2=0) then
    led1=0
    led2=1
    led3=0
    led4=0
    slot=0
    if (mem=2) and (m2<>0) then
    led1=0
    pause 300
    toggle led2
    led3=0
    led4=0
    slot=1
    if (mem=3) and (m3=0) then
    led1=0
    led2=0
    led3=1
    led4=0
    slot=0
    if (mem=3) and (m3<>0) then
    led1=0
    pause 300
    led2=0
    toggle led3
    led4=0
    slot=1
    if (mem=4) and (m4=0) then
    led1=0
    led2=0
    led3=0
    led4=1
    slot=0
    if (mem=4) and (m4<>0) then
    led1=0
    pause 300
    led2=0
    led3=0
    toggle led4
    slot=1
    if state=1 then
    green=0
    red=1
    if state=2 then
    green=1
    red=0
    if state=3 then
    green=1
    red=1
    if (but1=1) and (state=1) then
    gosub readmenu
    if (but1=1) and (state=2) then
    gosub recordmenu
    if (but1=1) and (state=3) then
    gosub erasemenu
    if but3=1 then
    gosub memorymenu
    if but2=1 then
    gosub statemenu
    goto startmenu
    recordmenu:
    debug "Record Menu",13,10
    if slot=1 then
    goto warningmenu
    if mem=1 then
    st=p1a
    ed=p1b
    if mem=2 then
    st=p2a
    ed=p2b
    if mem=3 then
    st=p3a
    ed=p3b
    if mem=4 then
    st=p4a
    ed=p4b
    recordmem:
    debug "2s pause before start recording",13,10
    PAUSE 2000
            FOR ADDR= st TO ed
     	for w = 0 to 15
            ADCIN temp, va
            va2=va + (temp>>4)
            NEXT
    va = (va2 */ 5000 ) >> 2
    va=va/10
            toggle red
            pause  824
            debug " Saved value:  ", dec va2," - ", dec va," In position  ", dec ADDR, 13,10
            debug " VA2 = ", dec va2,13,10
            I2CWRITE SDA,SCL,CTW,ADDR,[VA.highbyte]
            pause 10
            ADDR=ADDR+1
            I2CWRITE SDA,SCL,CTW,ADDR,[VA.lowbyte]
            pause 10
            ADDR=ADDR+1
            I2CWRITE SDA,SCL,CTW,mem,[addr]
            if but1=1 then      'stop recording
            pause 600
            goto startmenu
            toggle led1
            toggle led4
            NEXT
            red=1
    erasemenu:
    eraseblock:
    debug "erasing block",dec mem,13,10
    red=0
    I2Cread SDA,SCL,CTW,mem,[x]
    debug "before in position ",dec mem," - ",dec x,13,10
    I2CWRITE SDA,SCL,CTW,mem,[0]
    red=1
    memorymenu:
    if mem < 4 then
    mem=mem+1
    mem=1
    debug DEC mem,13,10
    pause 300
    statemenu:
    if state < 3 then
    state=state+1
    state=1
    debug "state change - ", DEC state,13,10
    pause 300
    WP pin pulled high? Low? Floating?
    Address pins pulled high? Low? Floating?
    WP is connected to ground. Same as all address pins of the eeprom.
    Then I'd suggest backing up a bit...
    Get uncomplicated...
    Write some code to just write a few values to the eeprom and read them back to verify what was written...THEN write the code you actually want to use...'cause I see a few flaws in your logic in the code written a few posts back.
  1. I2C Master/Slave 16F88/16F767 working code
  2. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  3. Replies: 1
    Last Post: - 28th January 2010, 22:15
  4. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  5. HARDWARE I2C SAMPLE CODE question
