Hi Darrenmac,
see this thread for configs.
Hi Darrenmac,
I have read the suggested post again. All examples in this post appear to set each option in the config seperatly, ie pic type, mclr, pwrt as seperate comands but the datasheet for the 16f688 shows a config register called 11.1 (page 100) with each option as seperate bits either set or cleared. Can I just send this as a binary string (or hex equivelent)? if so how?
It never worked that way for me, every newbie reads that and tries it,(I did) and it has never worked that I heard of. You can string the commands together though, like so:
The data sheet shows you what happens in those registers, but you can access them only at program time and require you to use the proper syntax as shown in Melanies post.Code:@ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _LVP_OFF & _CP_ALL & _DATA_CP_ON
Ok that clears that up a bit. I guess its more reading and experementing. Thanks
I have tried some of the examples in the suggested post but I get compile errors.
Here are some of what I have tried
@ CONFIG FOSC = HS
opcode expected instead of config
CONFIG OSCS=OFF ; Oscillator switch OFF
Same error
@ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
Same error
I am using Picbasicpro with microcode studios
Looks like you're still stuck...
I need some information... are you using Microchip's MPASM or MeLab's PM as the Assembler? or don't you know?
If you don't know, then I'll have to install MicroCode Studio which I don't ever use and see what the default's are when trying to compile for this chip.
Oh, finally, what version of PBP are you running?
