Reading variables - more clock cycles?
Results 1 to 2 of 2
    Aug 2007
    Default Reading variables - more clock cycles?
    If I want to keep a particular loop as fast as possible (fewest cycles), does it add more time to reference a value by it's variable name?
    For example, do these two code blocks take the same number of cycles to execute....
    EXAMPLE 1:
    myVar = 273
    EXAMPLE 2:
    (assuming SomeNum is already defined as a BYTE and loaded with the value "273")
    myVar = SomeNum
    And more specifically, when loading the registers of a 16-bit timer... let's say I already have the value "%01010101" loaded into a BYTE variable named "HighTimes" and "%11110001" loaded into a BYTE variable named "LowTimes".....
    EXAMPLE 1:
    TMR1H = %01010101
    TMR1L = %11110001
    EXAMPLE 2:
    TMR1H = HighTimes
    TMR1L = LowTimes
    Does this second example take longer to execute because it must go look up the value of the variable before the copy to the register?
    They are all equal.
    TMR1H = %01010101
    TMR1L = %11110001
    Produces;
       MOVLW 0x55
       MOVWF TMR1H
       MOVLW 0xf1
       MOVWF TMR1L
    HighTimes = 10
    LowTimes = 20 ' loading these vars is the only real time difference
    TMR1H = HighTimes
    TMR1L = LowTimes
    Produces;
       MOVF _HighTimes, W
       MOVWF TMR1H
       MOVF _LowTimes, W
       MOVWF TMR1L
    The 2nd version of course depends on which bank your vars are in.
    Could take more code if they're not in bank0.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. PBP instruction clock cycles
    By MOUNTAIN747 in forum General
    Last Post: - 31st January 2009, 02:53
  2. EM4095 Chip, get Clock and Data signals?
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 06:27
  3. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 11:48
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. Reading Array values into variables
    Last Post: - 21st March 2005, 10:30
