16F88 7 data bits
Results 1 to 13 of 13
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    I thought the DEFINE for SERIN/SEROUT stuck constant for the whole program...like you can't re-DEFINE it.
    They do - that is why I suggested using SEROUT for one and SEROUT2 for the other. They are not related by the defines
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Quote Originally Posted by paul borgmeier View Post
    AHA! Missed that!
    In the software serial routines, MELabs must be looking at the settings in order to determine how to send the data bits and set the parity right? Problem is it's a define and not a variable or it most likely could be changed on the fly.
    I sure hate to bit bang this but I may have to.
    Richard
    Feb 2003
    you do not have to, PBP has done the work for you.
    >>two adjacent pins connected together
    another thought - no need for adjacent pins - use SEROUT for 8N1 and SEROUT2 for 7N1 ... using the same output port pin.
    If PORTA.1 = 1 then ; check jumper
    SEROUT PORTB.0, .... ; need 8N1
    SEROUT2 PORTB.0, ... ; need 7N1
    will that work?
    Also, I do not see why you keep mentioning CCS??? We are taking PBP here
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    I'll give it a shot this morning. It "should" work.
    Why do I keep mentioning CCS? I only mentioned it once in an effort to show it is possible to do it But upon closer examination, it also only handles it in software only.
    Feb 2003
    Hi Richard,
    I hope this approach works for you.
    Best of the Day,
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Hi Richard,
    I this approach works for you.
    Best of the Day,
    I ended up using SER2 for the 7,N,1 Stuff then
    using HSER for the 8,N,1 Stuff.
    Check the Dip switch, Configure TXSTA, RCSTA, SPBRG to the values needed or Zero if not needed. This worked great and allowed me to still use the modifiers like in SER2.
    Thanks for the ideas.
    Richard
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  3. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 14:31
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
