Skimask... KISS it...
Just use the TX and TX pics at either end. Run full speed with a descent baud rate. Include periodic data bytes or "commands" in the data stream the indicate when the line should be High/Low. RX pic reads data, catches the command bytes and changes the line as needed.
Or just use one pic with the line in and then line out. Won't that work?
SteveB
