epic programmer not found ---HELP!
Results 1 to 11 of 11
    Feb 2008
    Unhappy epic programmer not found ---HELP!
    Hi Everyone,
    I purchased an EPIC programmer some time ago and finally got around to try to program today.
    But I'm stuck at the "Epic programmer not found" message.
    I don't think it can be the cable. The LED remains lit until I actually try to program the 16f876.
    I've removed my HP printer driver and set the parallel port to ECP in bios.( as instructed by MELabs)
    I've installed a Generic printer driver and set it to default.
    And yet, and yet. It can't find the EPIC programmer.
    I've rebooted until my thumb is raw.
    I was really hoping to start making dream machines today. And suggestions?
    Cheers
    MacQ
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by dmacq View Post
    Hi Everyone,
    Cheers
    MacQ
    The thumb need not be raw. Perhaps after you deleted the printer, Then try to delete the epic driver also.
    you may have to manage to see that the registry entries pertaining to printer and epic programmer driver are cleaned, and then reboot and the install the driver for epic programmer and try first. you may install the printer later. perhaps this might work.
    Sarma
    Apr 2006
    Alberta Canada
    check your power supply too... i think they say12v 1A
    Maybe the XP polling patch will help?
    http://www.melabs.com/support/patches.htm#xppolling
    Or, switch over to Winpic800; it supports the EPIC hardware (ETT PIC V3-V4 or GTP-07 options), and is IMHO a far better utility. Also lets you completely configure parameters, including the port settings.
    Anand
    Mar 2006
    Hyderabad (India)
    Anand
    I fear , we will be piling up programmer cards in the home / office, if we go on purchasing, the moment one doesn't work. Unless one is a serious professional programmer and his work suffers losses due to just a programmer, any one can scratch his head and look back at the programmer hardware or driver, we can settle things in a short time. added, we gain experience of servicing hardware.
    Most common faults can be attributed to loose connections or power supply related. of course, the interconnecting cable should be below the critical length as it creates lot of confusions and we may wrongly interpret as hardware fault.
    Sarma
    Feb 2008
    Red face epic programer not working
    Thank you all so much for helping out with this.
    But clearly, I'm going to have to back up and give this thing some thought this weekend.
    I'm using PicMate Pro and thought it would be just plug and play, but its led me through some strange error messages, finally arriving at "epic programer not found."
    I would dearly love to reinstall my printer driver if that's possible. I will try the polling patch as a first effort.
    Or should I aquire Micro Code studio?
    Does Winpic800 compile and Program?
    Sorry if these questions sound daft but this appears much more involved than programming my Basic Stamp2.
    And I would dearly love to make this work
    Cheers
    MACQ
    1: Or should I aquire Micro Code studio?
    2: Does Winpic800 compile and Program?
    3: Sorry if these questions sound daft but this appears much more involved than programming my Basic Stamp2.
    Cheers
    MACQ
    Hi MACQ,
    1: Easy to acquire, comes with P BASIC PRO
    2: NO -Winpic8000 only loads your HEX file into the PIC
    3: How do you do a stamp? Bootloader? You can load a bootloader into PIC and then program without using a programmer later.
    HTH
    JS
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. epic programmer to lcd
    By rdxbam in forum General
    Last Post: - 3rd November 2008, 23:35
  3. Need the programmer EPIC software
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2007, 11:42
  4. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 03:56
  5. EPIC Programmer - Works for all chips but the 16F876A
    By 4Lewis in forum mel PIC BASIC Pro
    Last Post: - 12th April 2006, 23:59
