Help ! New to programming and building a time Machine !
Results 1 to 7 of 7
    Mentor, Ohio
    Smile
    Hi Joe,
    Thank you for the write up. There should be some sort of requirement to "read this first" before being able to log on but that would deter the people that are in a "hurry" to finish a complete design by tomorrow morning.
    It's frustrating!
    We were all noobs at one time or another! As for the time machine idea, I think you will need a bigger PIC or maybe many PICs with an RS485 link between them all.
    BobK
    Quote Originally Posted by BobK View Post
    BobK
    The new PICs coming on line have a QFI (Quantum Foam Interface) module for instantaneous submolecular state transposition, as well as employing a MPTE (Multi Phase Turbo Enacabulator)...see below...
    Engineers last week were avidly reading a pamphlet published by
    Arthur D. Little, Inc., a venerable Cambridge, Mass, chemical and
    engineering research firm. Title: The Turbo-Encabulator in Industry.
    Excerpts: " ... Work has been proceeding in order to bring perfection
    to the crudely conceived idea of a machine that would not only supply
    inverse reactive current for use in unilateral phase detractors, but
    would also be capable of automatically synchronizing cardinal
    grammeters. Such a machine is the 'Turbo-Encabulator'. "The original
    machine had a base-plate of prefabulated amulite, surmounted by a
    malleable logarithmic casing in such a way that the two spurving
    bearings were in a direct line with the pentametric fan. ... The main
    winding was of the normal lotus-o-delta type placed in panendermic
    semi-boloid slots in the stator, every seventh conductor being
    connected by a nonreversible trem'e pipe to the differential
    girdlespring on the 'up' end of the grammeters. "Forty-one manestically
    spaced grouting brushes were arranged to feed into the rotor slipstream
    a mixture of high S-value phenylhydrobenzamine and 5% reminative
    tetryliodohexamine. Both of these liquids have specific pericosities
    given by P = 2.5C.n^6-7 where n is the diathetical evolute of
    retrograde temperature phase disposition and C is Cholmondeley's
    annular grillage coefficient. Initially, n was measured with the aid of a
    metapolar refractive pilfrometer . . . but up to the present date nothing
    has been found to equal the transcendental hopper dadoscope. ...
    "Undoubtedly, the turbo-encabulator has now reached a very high level
    of technical development. It has been successfully used for operating
    nofer trunnions. In addition, whenever a barescent skor motion is
    required, it may be employed in conjunction with a drawn reciprocating
    dingle arm to reduce sinusoidal depleneration."
    Need I say more?
    Would the be MicroChips
    ∞Fxxx
    I bet the data sheet is in continuous loop format.
    Mar 2006
    Pennsylvania, USA.
    Default But my homework is due tomorrow!
    Here I've wasted three years on flux capacitors! I hope Darrel gets the time-warp interrupts into Instant Interrupts 2008, I'd hate to miss my worm-hole because I was in a PicBasic pause command, and I refuse to build a time machine that uses assembly language. Will this make Long variables all relative?
    When I started programming we used punch cards, and the computer processor had tubes in it. The 'Impact' printer was housed in a cabinet because you couldn't stand the noise. An 18FXXX is more powerful than the computers that put a man on the moon. No wonder that it takes more than an hour to learn all that they are capable of. I've been learning for over thirty years now, and I'm still not finished.
    Hey Joe, can I borrow the time machine, my homework is due tomorrow!
    Jerry.
    If your oscilloscope costs more than your car...
    Quote Originally Posted by b1arrk5 View Post
    Jerry.
    Hi Jerry,
    I remember those big monsters, My Dad worked a while in a computer bookkeeping business
    and I remember studying fortran because My Dad had the manuals. Took up the whole room!
    That big, Iron Business Machine! I even scrapped one out once, the printer was 600 pounds.
    Official forum rules, yer on yer own for homework
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 01:59
  2. Programming TMR0 Interrupt in PICBasic
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 12th September 2006, 02:56
  3. 12f657 programming question
    By puggy in forum General
    Last Post: - 8th October 2004, 16:28
