LCDout and large filesize 18F452 -> paging problem?
Results 1 to 19 of 19
    Jan 2008
    Finland
    > Yes, does the code in Post #6 work?
    Well, did ya mean reversing direction-bit of portD.7?
    I don't think it would resolve the problem-
    in this case the problem is deepper-I think it is in compiler...
    The code works ok, only the LCDout routine is causing problems..
    (=jamming portD.7)
    m.
    Quote Originally Posted by mara View Post
    (=jamming portD.7)
    m.
    Ok, typo on my part...
    TRISD = %10000000 should have been
    TRISD = $40
    Did it work or not?
    Looking at your program as a whole, I think the problem is that the LED is actually coming on, but that it flickers too fast for you to see it. With the pulsout, you are seeing a .13 second pulse, if your code says something to the effect of:
    LED1 = 1
    LED1 = 0
    then you probably won't see it come on at all...unless you got really super special eyes.
    Be careful with 18Fs.. when you write to a PORT you should use LATx instead of PORTx. If you write to adjacent bits, you should write to a shadow register first, then copy it to the whole port to avoid the Read-Modify-Write behaviour.
    I would tend to change the LCDOUT statement... reading the Magn bit (from PORTD.7), save the result to a Temp variable then after show the result. When writing to Magn, you use LATD.7.
    I've never used, or had to use, LATD.x on the 18F's.
    But if you say it takes care of some of the R-M-W issues, then it must be true.
    Jan 2008
    Finland
    This might be worth deepper inspection..
    I'm sorry I didn't identify the problem clearly-basicly LCDout works just fine. LCD-display can be used only for testing purposes cause it's so damn slooooow.. o:-) That's why all lcd-routines are normally bypassed by "naytto" input signal. Only problem is that if I want to use LCDout for testing, it will shut down (low) portD.7 output (MAGN) as well.. There cannot be hardware problem cause in next line I put pulsout portD.7,65530 command for testing purposes and it will flash Led in portD.7 but I cannot understand why in previous line command portD.7=1 (Magn=1) will NOT illuminate the same led.. (see line marked in RED=near lines 145 and 182)
    as i said, you want to use LATD instead of PORTD. Pulsout also do more than a single PORT/LAT=x. If my memory serves me well it set the TRIS.. then do what it has to do. Hence wasting a few instruction cycle before and after... why the R-M-W behaviour don't happen.. or is reduced to a minimum.
    Jan 2008
    Finland
    Ok, u do have a point and that must be the issue here.. BUT..
    could it be so that the LCDout-command is causing this RMW behaviour and not the other way around?
    I mean without LCDout everything works fine.. o:-)
    what can I do about that build-in LCDout-command?
    I don't have time and energy to write my own LCDout-command..
    o:-)
    Jan 2008
    Finland
    Ok, Now i know it is about RMW. As I put "pause 5000" right after portD.7=1 command, the led in portD.7 will light for 5seconds.
    There ain't any other solution than find another port for output-like portB.1?
    Jan 2008
    Finland
    Ok, now it works: instead of portD.7=1 I write:
    latd.7=0
    latd.7=1
    and now portD.7 will stay high even if LCDout is used..
    BUT.. why do I have to do it that way? o:-)
