LCDout and large filesize 18F452 -> paging problem?
Results 1 to 19 of 19
    Post the code...
    Jan 2008
    Finland
    Code is basicly like this:
    DEFINE LCD_BITS 4
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 5
    TRISD = %01000000
    LED VAR portD.7
    --->8---(klipeti-klipeti)--->8--- (lots of stuff)
    Lcdsub:
    lcdout $FE,2,"hello"
    lcdout $FE,C0,"world"
    LED=1 ' This should illuminate the led?
    gosub Lcdsub
    LED=0
    goto Main
    So, if I replace LED=1 with pulsout portD.7,65530 it will blink..
    Otherwise it wont.. BUT..
    If I remove gosubs away, LED=1 will work and it LED will blink..
    Post the code...
    Quote Originally Posted by mara View Post
    It's this that makes it suspicious.
    And which version of PBP are you using?
    Jan 2008
    Finland
    yep, I know.. the code is 500 lines...
    I just tried to save some bandwidth.. o:-)
    > And which version of PBP are you using?[/QUOTE]
    pbpro v:2.50a and uCodeStudio+ v:3.005
    Ok, how about this code, and ONLY this code:
    DEFINE LCD_BITS    4
    DEFINE LCD_DBIT    0
    DEFINE LCD_RSBIT  4
    DEFINE LCD_EBIT    5
    TRISD = %10000000
    LED VAR portD.7
    Lcdsub:  lcdout $FE,2,"hello" : lcdout $FE,C0,"world" : return
    main:  LED=1 : gosub Lcdsub : pause 500 : LED=0 : pause 500 : goto Main
    Jan 2008
    Finland
    Default Looong IF-THEN-ELSE structures?
    Well, I dunno.. BUT I got another question..
    What would happen if IF-THEN-ELSE overlaps from memory-page to another? Is it allowed? Is pbp-compiler capable of handle veeeeery loooooong IF-THEN-ELSE structures (like 200lines long?) including gosubs from page to page? If not-should I get a warning? o:-)
    I don't have any problem with what you're talking about, with 2.50a anyways. But quite frankly, I just avoid it altogether by just making the 'middle' of the If/Then another routine.
    I've had some programs (one in particular), over 4300 lines long (and that's compacted with a lot of colons like I do often, uncompacted, figure roughly 13,000+ lines). Never had a problem with the amount of code inside of an If/Then, Select Case, While/Wend, or otherwise.
    You tend to forget things like RETURN after a GOSUB, or maybe you RETURN from somewhere that you had GOTO'd instead of GOSUB'd. Keep that in mind. I just fixed a buried GOSUB (one of the drawbacks of 'compacting' source code) that would only show up after the loop went thru itself 32 times and ended up causing a stack overflow which killed my entire OS on the one project. I've been fighting it for over 6 months now.
    And paging really isn't so much of an issue, moreso with 18F series PICs, and even moreso with PBP for the last few years.
