> It's this that makes it suspicious.
yep, I know.. the code is 500 lines...
I just tried to save some bandwidth.. o:-)
> And which version of PBP are you using?[/QUOTE]
pbpro v:2.50a and uCodeStudio+ v:3.005
Ok, how about this code, and ONLY this code:
Code:DEFINE LCD_BITS 4 DEFINE LCD_DREG PORTD DEFINE LCD_DBIT 0 DEFINE LCD_RSREG PORTD DEFINE LCD_RSBIT 4 DEFINE LCD_EREG PORTD DEFINE LCD_EBIT 5 TRISD = %10000000 LED VAR portD.7 Lcdsub: lcdout $FE,2,"hello" : lcdout $FE,C0,"world" : return main: LED=1 : gosub Lcdsub : pause 500 : LED=0 : pause 500 : goto Main END
Well, I dunno.. BUT I got another question..
What would happen if IF-THEN-ELSE overlaps from memory-page to another? Is it allowed? Is pbp-compiler capable of handle veeeeery loooooong IF-THEN-ELSE structures (like 200lines long?) including gosubs from page to page? If not-should I get a warning? o:-)
I don't have any problem with what you're talking about, with 2.50a anyways. But quite frankly, I just avoid it altogether by just making the 'middle' of the If/Then another routine.
I've had some programs (one in particular), over 4300 lines long (and that's compacted with a lot of colons like I do often, uncompacted, figure roughly 13,000+ lines). Never had a problem with the amount of code inside of an If/Then, Select Case, While/Wend, or otherwise.
You tend to forget things like RETURN after a GOSUB, or maybe you RETURN from somewhere that you had GOTO'd instead of GOSUB'd. Keep that in mind. I just fixed a buried GOSUB (one of the drawbacks of 'compacting' source code) that would only show up after the loop went thru itself 32 times and ended up causing a stack overflow which killed my entire OS on the one project. I've been fighting it for over 6 months now.
And paging really isn't so much of an issue, moreso with 18F series PICs, and even moreso with PBP for the last few years.
> You tend to forget things like RETURN after a GOSUB..
Yep, gosubs and if-then-else-endif structures are like women-
one has to be veeery careful with them.. o:-)
I downsized the code a little bit - any comments?
It works if naytto is low,
If naytto is high then portD.7 wont go high (except pulsout-command)
> Yes, does the code in Post #6 work?
Well, did ya mean reversing direction-bit of portD.7?
I don't think it would resolve the problem-
in this case the problem is deepper-I think it is in compiler...
The code works ok, only the LCDout routine is causing problems..
(=jamming portD.7)
m.
