PIC18F6680 programming
Results 1 to 18 of 18
    Jan 2008
    and 4 real who cares about spelling this is not english class.
    Quote Originally Posted by gopher View Post
    Apparently not...
    Eye dunt no wat eye waz tinkin...4 real...4 shur.
    Eym nut 733t like 50m3.
    Jan 2008
    The PIC is not blank its already soldered onto a piece of working equipment.
    The new devices we reprogram with a laptop that has special software that sends data via the serial port straight into the max232e thats wired directly to the PIC. The older devices are exactly the same except no connection port and no mac232e chip. from what i can see there are only 3 connections from the max232 the the PIC
    I just don't know what they connect to..... RB5,RB6,RB7,Vdd,Vss or MCLR ?
    Dec 2007
    Denmark
    Use Google and do a little research about ICSP, that might help.
    Jan 2008
    I hope you don't get the idea that i came here without trying to research this stuff.
    Look here
    http://s261.photobucket.com/albums/i...rrent=BACK.jpg
    and here
    http://s261.photobucket.com/albums/i...rent=front.jpg
    If someone could tell me what pins on the PIC the 3 data lines connect to??? Is that asking 2 much?
    Mar 2005
    Iowa, USA
    The problem here is without knowing the hardware or software differences between the two versions, who's to say the second version (with the max232) was loaded with a bootloader to allow for field updates? The first version could have been programed using ICSP or could have just been programmed and soldered into the circuit without regard for future updates.... hence the second version that is field updateable.
    Wisdom is knowing what path to take next... Integrity is taking it.
    Ryan Miller
    Jan 2008
    OK good point. Thanks for the reply. that is a very real possibility. Since the PIC chips are exactly the same I think it may be worth a try to save some money.
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 03:37
  2. 16F676 programming problem
    Last Post: - 18th May 2009, 17:39
  3. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 16:51
  4. Who can help me checking my Programming
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 15:08
  5. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 16:04
