PIC18F6680 programming
Results 1 to 18 of 18
    Mentor, Ohio
    Smile
    Hi Gopher,
    I noticed 9 holes on the front view. Alot of products in the alarm industry have either pads or holes for ICSP programming. It's possible that these holes might be for a tester or programmer. Try metering them to see if they connect to the ICSP pins on the PIC. Like you said, you've got alot of these boards. The RS232 chip could be for sending and receiving data and/or could be for a bootloader as was mentioned earlier.
    HTH,
    BobK
    Jan 2008
    ok here is what i traced
    max232 pins 2,5 (INVALID, FORCEON) goes to PIC pin 30 (RC0/T1OSO/T13CKI)
    max232 pin 4 (T1IN TTL/CMOS Transmitter Outputs) goes to PIC oun 31 (RC6/TX/CK)
    max232 pin 6 (R1OUT TTL/CMOS Receiver Outputs) goes to PIC pin 32 (RC7/RX/DT)
    does this sound like it makes any sence? can USART pins be used to program a part of the chips memory ?
    Quote Originally Posted by gopher View Post
    No, not without some sort of preloaded bootloader software (and the knowledge to operate it) loaded into the PIC that's already soldered on the PCB.
    You need to hook into PGC/PGD/PGM/MCLR and all Vdd and Vss, and have those pins isolated from major loads on the rest of the PCB to keep from messing with the programming signals.
    But you already knew that judging from Post #9...right?
  1. Data Programming Error at 0000
    By cpatnoi in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2009, 03:37
  2. 16F676 programming problem
    Last Post: - 18th May 2009, 17:39
  3. Problems programming
    By Lionheart in forum General
    Last Post: - 7th December 2008, 16:51
  4. Who can help me checking my Programming
    By slimpeng in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 15:08
  5. Some questions for programming
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 16:04
