Single event data logger wth LCD
Results 1 to 13 of 13
    Easy to do with almost all RTC and a external EEPROM, or skip the RTC and use ElapsedTimer example.
    Jan 2008
    lincoln uk
    Question Single even data logger
    I don't understand your reply and is it not possible to impliment solution with a single chip?
    Do a 16F84 not have enough data space?
    Rgds
    Quote Originally Posted by med2007 View Post
    Rgds
    Sure it do (does...) have enough data space...
    If you want to record 64 events, each of which are only one byte wide data, or 32 events of 2 byte data, or 16 events of 4 byte data, or 8 events of 8 byte data, or 4 events of 16 byte data, or 2 events of 32 byte data, or one event of 64 byte data.
    See where I'm going with this?
    We don't know: what you are logging (A) and how often you are logging it (B).
    A x B = total data space required.
    Some simple math and a quick trip to the datasheets will answer all your questions.
    Jan 2008
    lincoln uk
    Smile Data logger
    As a complete NOOB I am struggling again, my interrupt handler doesn't work. It's for a timer
    and this code is only part of the complete project. It should pulse portb.0 and susequently portb.2 It does not work. Please help if you have the time. Rgds Mike
    'Using 16F628 4MHz crystal
    secs var byte
    mins var byte
    clear
    option_reg = %10000111
    intcon = %10110010
    test:
    on interrupt goto seconds
    goto test
    disable
    seconds: 'Interrupt Handler 'Disable interrupts during Handler
    secs=secs+1
    intcon.2=0 'interrupt bit 2 must be rest in software
    if secs=10 then
    mins=mins+1
    secs=0
    high portb.0
    pause 1
    low portb.0
    if mins=5 then gosub minutes
    resume test
    enable 'Re-enable interrupts after Handling
    minutes:
    mins=0
    intcon.2=0
    secs=0
    high portb.2
    pause 5
    low portb.2
    The setup is a bit goofy in my mind, but if it works for you, great...
    This is the way I'd do it (keep in mind I don't have my 'stuff' handy, so the register setup might be off)
    secs var byte : mins var byte : dummycounter var byte
    clear
    option_reg = %10000111 : intcon = %10110010
    goto skip_ints_and_subs
    on interrupt goto int_handle
    disable
    int_handle:
    intcon.2 = 0
    secs = secs + 1
    if secs = 10 then
         mins = mins + 1 : secs = 0 : high portb.0 : pause 1 : low portb.0
                                '1ms?  sure you'll see the pulse?
    if mins = 5 then
         mins = 0 : secs = 0 : high portb.2 : pause 5 : low portb.2
                                '5ms?  probably won't see this pulse either
    resume
    enable
    skip_ints_and_subs:
    dummycounter = dummycounter + 1
    Again, check your pulse length on the LED flash. Increase it maybe.
    Jan 2008
    if secs = 10 then
    mins = mins + 1
    Did you mean:-
    if secs = 60 then
    mins = mins + 1
    ... Steve
    Quote Originally Posted by scarroll01 View Post
    if secs = 10 then
    mins = mins + 1
    Did you mean:-
    if secs = 60 then
    mins = mins + 1
    ... Steve
    Nope...if the O/P put 10 and his minutes are 10 seconds long, then great...
    Besides...if you're making something, and something else isn't working...I don't know about you, but I'd rather wait 10 seconds to see if something doesn't work rather than 60 of them seconds.
    Can always change it later...
    Jan 2008
    lincoln uk
    Smile Single Event Data Logger with LCD
    Thanks for your help with my project, it is now almost complete and working well enough.
    In the end I didn't use an Interrupt Handler, just counted until intcon.2=1, fairly accurate for what I want, about +-0.02%, according to my real time clock.
    I've packaged the result as a demo, hoping to strike up some interest with a few of my chums...you never know?
    Rgds
    Mike
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
