Unwanted output signal jitter
Results 1 to 21 of 21
    Nov 2007
    West Covina, CA
    Thumbs up My thoughts exactly...
    But, be all that as it may be, it's nearly impossible to determine what the ECM will determine should be the NEXT pulse width. If it was me, I think I'd try a system that would LAG by one pulse event. Keep tabs on the previous pulse, modify that pulse width, shoot that pulse width on the next event, while at the same time, using a timer, measuring the current pulse width, while again, using a timer, to keep track of the current pulse width and stop it as required.
    That was my initial thought too! But since I'm just coming out of the starting gate, I didn't know how that would be possible without a crystal ball. Thanks to some info I found on slick ways of using timers by DT, you're right, I think I will drop the notion of delaying the start of the pulse and keep tabs of the previous pulse to work off that.
    This circuit will not be used blindly but in a monitored state on a dyno and is only the basis of the system. I know there are products out there for this but then there are also more than one type of shoes too.
    Thanks for the confirmation!
    Quote Originally Posted by LinkMTech View Post
    I guess my big question is...why do you want to mess with the pulse width anyways?
    Are you adding on some crazy turbo, tuned pipe type things or what?
    I mean, closed loop is closed loop is closed loop. It's efficient, clean, keeps parts where they're supposed to be, etc.etc.etc. (and again I don't what kind of system you're dealing with).
    Now...WOT is another story... Are you looking to basically 'bypass the rom' in the ECM and feed more fuel under WOT/open-loop conditions?
    Nov 2007
    West Covina, CA
    Default No O2
    Most street bikes (not all) do not currently use an O2 sensor, so minor adjustments to the fuel delivery are possible and needed in different parts of the RPM range when aftermarket upgrades are installed and will help smooth out the power delivery. You'd be surprised how much a little improvement feels "at the seat of the pants" to the rider. Maybe you already know.
    Now the +/-20% range is adjustable and will probably never see 20% and may be reduced to some narrower range in the end, but until then, I'm starting at +/-20%.
    Now since I'm taking your advice to sample the leading pulse to configure the next pulse out, I downloaded Mr. DT's Instant Interupt-14 super duper program template and aww man, all I could do was look straight up! You guys are in the zone to understand this stuff. But if I'm gonna eat that elephant, it'll be one byte at a time.
    Quick question,... will I need to have a PIC device with 4 timers to be able to trigger off 4 inputs to "sample one, build the next"?
    Mar 2006
    Pennsylvania, USA.
    Lightbulb And now for something completly different,
    In keeping with my philosophy of keeping it simple, how about this idea, dump the ADC altogether, and use the CCP input to read the signal pulse duration. Bruce has posted an example how to do it using Darrel's Instant Interrupts. Instead of a pot to adjust, just read two buttons, up and down. I think you could get far greater resolution than you will turning a pot, and you could read the buttons using interrupts, or watch them in a loop. Wouldn't the four input signals, and the four injector pulses be pretty much identical for each revolution? I wonder if you could just read one or two input pulses on each revolution, and make all the outputs identical. Given the mass of the pistons and the fact that they are connected to the same crankshaft I'd be surprised if there needs to be a great variance between cylinders on a single revolution. If you can assume that the input signals and output signals would be identical that makes you job a lot easier, one timer would do it. I'm thinking that having an up and down button would allow a rider to make adjustments on the track, not just on a dyno, it would be hard to tweak a pot while sitting on a bike at speed, and eventually you will likely want to get this on the road I imagine. Your software could adjust the range of adjustment based upon the rpms of the engine, so at higher rpms you couldn't make a drastic change if you held a button too long, but at lower rpms holding the button could make a faster (greater percentage) change.
    Jerry.
    If your oscilloscope costs more than your car...
    Mar 2006
    Pennsylvania, USA.
    Default Addendum.
    I found the link I was thinking of;
    http://www.picbasic.co.uk/forum/show...errupt+capture
    this shows Bruce's example for reading the pulse width.
    Jerry.
    Nov 2007
    West Covina, CA
    Default Heck yeah, more good info
    It's been a long day, my eyes hurt from all the reading...
    Making all the outputs the same on a pass makes capitol sense. Then update with the gathered timer info next time around. I'm all for simple as soon as I get some speed on this learning curve.
    The adjustments will be almost a one time setting until the bike gets upgraded again or has to be readjusted on track day at the track due to temp., elevation, and things like that. But one thing for sure, can't have the rider racing one handed except for cruel entertainment pleasure on the spectators part.
    Thanks for the added info b1arrk5. I will study it and try it out.
    If I was you, I'd kill that 20% idea and stick with something less, like maybe 5%. Like I said earlier, 20% is the difference between stoich and melted pistons, especially at high rev's, heck 20% is the difference between slobbering rich (say 12.5:1) and the lean side of detonation (12.5:1 - 20% = 15:1).
    One timer, keep track for 4 start/end value pairs, do the subtraction math on the pairs to find time differences.
    Quote Originally Posted by b1arrk5 View Post
    In keeping with my philosophy of keeping it simple...
    Jerry.
    I agree 100%+ with every one of those comments...and with that agreement and $1.25, you might be able to buy a bottle of Dew!
    But seriously, dead on, let the hardware do the work for you.
  1. 16F1827 setup
    Last Post: - 10th March 2011, 00:04
  2. Replies: 24
    Last Post: - 1st December 2009, 09:01
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. Serious Serial Situation Setbacks...
