Internal eeprom - erase block
Results 1 to 33 of 33
    hehehe
    all true
    but like i said i'm just experimenting with reading and writing.
    When i manage to get it right i will move to external eeproms
    Microchip states that it's "1,000,000 write EEPROM endurance".
    I hope it's true
    Quote Originally Posted by ruijc View Post
    Search the microchip website. Somewhere there's an App-Note that talks about Microchip's EEPROM endurance and how to get the most out of it.
    yeah i remind this one... but i'm not sure if it wasn't only for EXTERNAL eeprom.. playing with page write, voltage and temperature seems to be external dedicated tricks to me... but yeah i may have missed the one about PIC!
    http://www.picbasic.co.uk/forum/showthread.php?t=1670
    Yep, got me again, that's the one I was talking about. For some reason, I thought it was for internal eeprom/flash. I have yet to totally wipe out a flash PIC or on chip EEPROM on a PIC yet. I've worn out a small chunk of one, like the first 64 bytes of an older 18F4620, but not completely...yet...today...or even this year... I can sure try
    Jan 2006
    Istanbul
    Some statements from 24LC32 datasheet.
    • Endurance:
    - 10,000,000 Erase/Write cycles
    guaranteed for High Endurance Block
    - 1,000,000 E/W cycles guaranteed for
    Standard Endurance Block
    In the same datasheet, there is also this;
    "...the first 4K, starting at address 000,
    is rated at 10,000,000 E/W cycles guaranteed. The
    remainder of the array, 28K bits, is rated at 100,000 E/W cycles guaranteed."
    Do I get it wrong, or the datasheet contradicts itself?
    Default No contradictions - High & Standard endurance blocks
    What this is saying is that the first 4k locations are 'high endurance' (and probably physically larger). The remaining 28k bytes are 'standard endurance'.
    Just make sure your code always starts to store data from address 0 so the low adfdresses get most writes and the highest see less writes.
    HTH
    Brian
    Jan 2006
    Istanbul
    Quote Originally Posted by BrianT View Post
    HTH
    Brian
    Hi Brian,
    What it says is clear.
    The thing is, for standard block, it says 1M cycle at the beginning, but 100K cycle at the end of the statement. Read it again!
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. config bits
    By brianD in forum mel PIC BASIC Pro
    Last Post: - 9th February 2010, 14:45
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 20:42
