I don't understand this code!
Results 1 to 40 of 47
    Jan 2006
    New Hampshire, USA
    Default I don't understand this code!
    I am trying to generate a quasi sine wave at 60 hz. The program runs but the waveform is upside down. I could change the circuit to accept the upside down wave, but I would like to know what is going on. This is my simple code:
    REM DEVICE = 12F675 '12F629 CAN ALSO BE USED
    REM USE INTERNAL OSCILLATOR, OUTPUT IS ON GP4 (PIN 3)
    REM CONFIGURATION: INTOSC CLOCKOUT, WDT DISABLED, PWR UP ENABLED,
    'MCLR = OUTPUT PIN, BROWN OUT DISABLED, NO PROTECTION
    REM 60 HZ OUTPUT IS ON PINS 7 AND 6
    REM OSCILLATOR CHOICE: USE 101, INTOSC, CLKOUT
    OPTION_REG.5 = 0 'OTHERWISE GPIO.2 IS AN INPUT
    TRISIO = %111111 'SETS ALL PORTS TO OUTPUT
    ANSEL = 0 'SETS ALL DIGITAL MODE
    DEFINE OSCCAL_1K 1 'FOR OSCILLATOR CALIBRATION, DON'T KNOW HOW IT WORKS
    HIGH GPIO.0 'INITIAL CONDITIONS
    HIGH GPIO.1
    START:
    LOW GPIO.1
    PAUSEUS 4168 ' ON TIME
    HIGH GPIO.1
    PAUSEUS 4167 'DEAD TIME
    LOW GPIO.0 'SETS PIN 7 LOW
    PAUSEus 4168 'FOR 4.168 MILLISECONDS
    HIGH GPIO.0
    GOTO START '60 HZ FREQUENCY
    If I change all highs to lows and all lows to high in the loop, I get the idenical same hex code. I would expect that
    high gpio.0
    highgpio.1
    start:
    low gpio.1
    would give a different hex code than
    high gpio.0
    high gpio.1
    start:
    high gpio.1
    Russ
    Apr 2006
    New Hampshire USA
    Question 60 Hertz quasi sine wave
    Hi Russ,
    Could you explain how the waveform is upside down?
    Do you mean that the 60 Hertz quasi sine wave is upside down on your oscilloscope display? Switch your scope “triggering” from plus(+) to minus(-).
    -Adam
    Jan 2006
    New Hampshire, USA
    Thanks, I should have said that: I want the output to be low for the short time (4+ms) and high for the long time (12+ms). I think the program should do that, but it doesn't. The output is high for the short time and low for the long time.
    USA - Arizona
    Your main code looks fine:
    START:
    LOW GPIO.1
    HIGH GPIO.1
    HIGH GPIO.0
    Your startup code does not:
    TRISIO = %111111
    This sets all pins to <U>inputs</U>. You want to use:
    TRISIO = %001000 '(since GPIO3 is input only anyway)
    Quote Originally Posted by languer View Post
    Except for the fact that HIGH and LOW automatically set the pins as outputs...
    Now then...what is this output thing? Is this a 2 bit R/2R D/A ladder type setup or what is it?
    If it was me, i would use a timer interrupt, but add somes extra filter outside.
    I don't understand what you mean by
    Quote Originally Posted by Russ Kincaid
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
