5x5 display 16f648a
Results 1 to 7 of 7
    If you add 2 more rows and make it a 5x7 display, I've got a set of lookup tables already made up for the complete ASCII character set, should plug right into what you've got going.
    Originally, I used the character tables for a 122x32 graphic LCD, and now I'm using it on a 130x130 4K color Nokia knockoff LCD (in addition to a 16x2 LCD, all at the same time!).
    I'll post them here when I get a chance...
    Jul 2007
    Question Nokia Lcd
    Hi Skimask,
    I would like to know where you are getting your Nokia color LCD from?
    Thanks!
    J-P
    Quote Originally Posted by GrandPa View Post
    Hi Skimask,
    Thanks!
    J-P
    Sparkfun for the first couple along with the breakout boards, eBay for the rest.
    Got a few of the connectors from Mouser (I think, don't remember), going to send off and have a few breakout boards made for myself.
    I've also got a rather LONG search set up on eBay that shows only the compatible phones which use that particular display and only those particular displays.
    Copy the following into the search bar and hit enter:
    nokia -6620 -6230 -6061 -3220 -73* -n9* -52* -77* -6500 -57* -53* -88* -6101 -6126 -6265 -6680 -e6* -6288 -n7* -6133 -8600 -6300 -6230i -6010 -5610 -9300 -3310 -5110 -8810 -n8* -3250 -5500 -6111 -6280 -8850 -6120 -3360 -6360 -6600 -3230 -8210 -e90 -n93 -e5* -1110 -8910
    Took me awhile to figure out which ones work and which ones don't. And then there's the problem with the different controllers, Philips vs. Epson. Minor differences in programming. Try to do anything out of the ordinary, either one or the other won't work. I'm using the Epson command set right now, but can't get the scrolling to work, which leads me to believe I've got a Philips controller. Not sure what's going on, but I really don't care either, 'cause it works great in the basic modes.
    And here they are, 3 lookup lines, split them up as you see fit. ASCII characters $0-$7E.
    The first 32 are 'special characters', as indicated below.
    All characters are in 5 byte groups, one byte per VERTICAL line on the display, 5x7 format. The bottom bit in each character is usually blank except for those characters which 'drop below the line'.
    lookup5x7_0: '0-31
    lookup alphachar , [ _
    $80,$80,$80,$80,$80,$c0,$c0,$c0,$c0,$c0,$e0,$e0,$e 0,$e0,$e0,$f0,$f0,$f0,$f0,$f0,$f8,$f8,$f8,$f8,$f8, $fc,$fc,$fc,$fc,$fc,$fe,$fe,$fe,$fe,$fe,$ff,$ff,$f f,$ff,$ff,_ '0-7 1-8 lines
    $fe,$83,$81,$83,$fe,$fe,$c3,$c1,$c3,$fe,$fe,$e3,$e 1,$e3,$fe,$fe,$f3,$f1,$f3,$fe,$fe,$fb,$f9,$fb,$fe, $fe,$ff,$fd,$ff,$fe,$fe,$ff,$ff,$ff,$fe,_ '8-14 battery charge levels
    $ff,0,0,0,0,$ff,$ff,0,0,0,$ff,$ff,$ff,0,0,$ff,$ff, $ff,$ff,0,0,0,0,0,$ff,0,0,0,$ff,$ff,0,0,$ff,$ff,$f f,0,$ff,$ff,$ff,$ff,$ff,0,0,0,$ff,$ff,$ff,0,$ff,$f f,$81,$81,$81,$81,$81,_
    $c3,$c3,$c3,$c3,$c3,$e7,$e7,$e7,$e7,$e7,$c0,$80,0, $1,$3,$f9,$f3,$e7,$cf,$9f,$3,$1,0,$80,$c0,$9f,$cf, $e7,$f3,$f9 ] , alphadata '15-31 block fillers of varying density
    lookup5x7_1: '32-81
    0,0,0,0,0,0,0,79,0,0,0,7,0,7,0,20,$7F,20,$7F,20,36 ,42,$7F,42,18,19,19,8,$64,98,54,73,85,34,80,0,5,3, 0,0,28,34,65,0,0,0,0,65,34,28,20,8,62,8,20,8,8,62, 8,8,0,80,48,0,0,_ '32-44
    8,8,8,8,8,0,96,96,0,0,32,16,8,4,2,62,81,73,69,62,0 ,66,$7F,64,0,66,97,81,73,70,33,65,69,75,49,24,20,1 8,$7F,16,39,69,69,69,53,60,74,73,73,48,1,$71,9,5,3 ,_ '45-55
    54,73,73,73,54,6,73,73,41,30,0,54,54,0,0,0,86,52,0 ,0,8,20,34,65,0,20,20,20,20,20,0,65,34,20,8,2,1,81 ,9,6,50,73,73,65,62,$7E,17,17,17,$7E,$7F,73,73,73, 54,_ '56-66
    62,65,65,65,34,$7F,65,65,34,28,$7F,73,73,73,65,$7F ,9,9,9,1,62,65,73,73,$7A,$7F,8,8,8,$7F,0,65,$7F,65 ,0,32,64,65,63,1,$7F,8,20,34,65,$7F,64,64,64,64,$7 F,2,12,2,$7F,_ '67-77
    $7F,4,8,16,$7F,62,65,65,65,62,$7F,9,9,9,6,62,65,81 ,33,94 ] , alphadata '78-81
    lookup5x7_2: '82-126
    Lookup alphachar , [ _
    $7F,9,25,41,70,70,73,73,73,49,1,1,$7F,1,1,63,64,64 ,64,63,31,32,64,32,31,61,64,56,64,63,99,20,8,20,99 ,7,8,$70,8,7,97,81,73,69,67,$7F,65,65,0,0,2,4,8,16 ,32,_ '82-92
    0,0,65,65,$7F,4,2,1,2,4,64,64,64,64,64,0,1,2,4,0,3 2,84,84,84,$78,$7F,72,68,68,56,56,68,68,68,32,56,6 8,68,72,$7F,56,84,84,84,24,8,$7E,9,1,2,$C,82,82,82 ,62,_ '93-103
    $7F,8,4,4,$78,0,68,$7D,64,0,0,32,64,68,61,$7F,16,4 0,68,0,0,65,$7F,64,0,$7C,4,24,4,$78,$7C,8,4,4,$78, 56,68,68,68,56,$7C,20,20,20,8,8,20,20,24,$7C,$7C,8 ,4,4,8,_ '104-114
    72,84,84,84,32,4,63,68,64,32,60,64,64,32,$7C,28,32 ,64,32,28,60,64,48,64,60,68,40,16,40,68,$C,80,80,8 0,60,68,$64,84,76,68,8,52,65,0,0,0,0,$7F,0,0,_ '115-124
    0,0,65,52,8,0,8,4,8,4 ] , alphadata '125-126
    Thanks some more to play with. lol. I was using mister e's picmulticalc to draw out the 5 rows for my display, worked nice.
    Quote Originally Posted by nomad View Post
    I'm in the process of adding a whole load of extra 'characters', call them 'graphics' characters, little airplanes, cars, etc, sort of animations if you will, consecutive characters which will end up resembling things like that airplane flying by, car driving, slot machine graphics, stuff like that. They'll take up the rest of the ASCII set from 128-255, and if I run out of room, change the byte to a word, add a couple of if/then's, and go with it. I'll re-post the whole thing when I get done with it all.
  1. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 20:07
  2. Replies: 2
    Last Post: - 14th July 2008, 22:11
  3. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 13:12
  4. Replies: 14
    Last Post: - 26th September 2007, 05:41
  5. graphics display
    By adlinsystems in forum mel PIC BASIC Pro
    Last Post: - 12th June 2004, 12:53
