mekohler, I don't think your design using an 74LS174 will be able to drive the current you are anticipating using. Even with only 20 Ma. per led string in parallel, thats 40Ma. An normal 74LS series part can at best case source 5Ma. You are going to need a high power sourcing device such as a PNP transistor to source the required 40+ Ma. I beleive after your design has been prototyped you will find that if you are multiplexing the displays at any kind of rate you will lose almost all of the intensity. Therefore you will have to increase the current to the display system. Most wallboard displays you see in stores for advertising use anywhere from 100 to 500 Ma. as the display is multiplexed and switching at high speeds. I suggest looking at Allegro semiconductor as they have a variety of sourcing drivers available...
