LED Matrix Question
Results 1 to 29 of 29
    Sep 2007
    There is no need to buffer the rows (the PIC end) - this isn't the weak entity. It's the columns that may need the boost.
    agreed. would adding another ULN to the column make a difference
    T.Jackson's Avatar
    T.Jackson Guest
    Personally, I think the diagram that Sayzer posted might be right down your alley for what you need. (it looks quite correct) Bout the only thing I'd add to it is - some current boosting for the columns (if I wanted the display really nice & bright) Handful of BJT's or couple of UNL2003 would do nicely.
    Sep 2007
    The only thing he does differently is use a 4 to 16 decoder though (?).
    T.Jackson's Avatar
    T.Jackson Guest
    It's best to start by building / learning from other people's “know-to-be-good” circuits before you endeavor in developing your own. Eventually, you'll begin to see all these circuits as nothing more than pieces of a jigsaw puzzle. The jigsaw being your "target", your end-goal, where you will collate the pieces that you gather, modify, or develop over time. No point reinventing the wheel unless needed.
    Best of luck with it.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. Newbie question about switch + led
    By mradde in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 18:40
  4. Replies: 27
    Last Post: - 7th December 2007, 23:28
  5. LCD will not start
