LED Matrix Question
Results 1 to 29 of 29
    mekohler, I don't think your design using an 74LS174 will be able to drive the current you are anticipating using. Even with only 20 Ma. per led string in parallel, thats 40Ma. An normal 74LS series part can at best case source 5Ma. You are going to need a high power sourcing device such as a PNP transistor to source the required 40+ Ma. I beleive after your design has been prototyped you will find that if you are multiplexing the displays at any kind of rate you will lose almost all of the intensity. Therefore you will have to increase the current to the display system. Most wallboard displays you see in stores for advertising use anywhere from 100 to 500 Ma. as the display is multiplexed and switching at high speeds. I suggest looking at Allegro semiconductor as they have a variety of sourcing drivers available...
    Sep 2007
    Actually, it is labeled incorrectly. My book says to use 74S138:
    "In this application I used a 74S138 decoder to provide the column negative power supply select. The selection of the S technology decoder was selected over the more common LS technology to sink the most current (LED's fully lit) as possible"
    Does that make any difference? The low level output current for the 74s138 is 20mA...still, according to you that is way too low. The ULN2803A is the transistor array for the "rows", which http://www.electronelec.co.uk/uln2803a.htm says outputs current to 500mA
    Should I just place a second ULN2803A after the decoder?
    T.Jackson's Avatar
    T.Jackson Guest
    Those LEDs in the matrix arrays are very efficient. You'll get "satisfactory" light output from only 2-3mA for ea LED. The 74LS138, if you sink current from it, it might be adequate enough.
    mekohler, Like I said in my earlier post, What are you going to use to source the current to the paralleled led strings?
    Sep 2007
    I'm new to all of this. I thought thats what the ULN did. Pretty much what you see in my last post with the 2 pictures is all I have. I wouldn't know what else to add and in what config.
    T.Jackson's Avatar
    T.Jackson Guest
    There is no need to buffer the rows (the PIC end) - this isn't the weak entity. It's the columns that may need the boost.
    Sep 2007
    agreed. would adding another ULN to the column make a difference
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  3. Newbie question about switch + led
    By mradde in forum mel PIC BASIC Pro
    Last Post: - 24th January 2009, 18:40
  4. Replies: 27
    Last Post: - 7th December 2007, 23:28
  5. LCD will not start
